Subject: UPGRADING LIBRARIES
Mycrofted opened this issue on Oct 13, 2011 · 5 posts
Mycrofted posted Thu, 13 October 2011 at 5:16 AM
How do I import the contents of Poser 8's  library into Poser 9?
saibabameuk posted Thu, 13 October 2011 at 5:27 AM
Top of the Library is a little man with a cross + add runtimes seems to work for me.
hborre posted Thu, 13 October 2011 at 9:09 AM
That method, in essence, is lilnking your P8 library to P9.  It would not be advicable to import all the files within the P8 runtime folder because the Python script for P9 has changed.  Mixing files can potentially disable that function.
grichter posted Thu, 13 October 2011 at 4:09 PM
Not anywhere near my copy of poser (it's 6,200 plus miles away at this second in time) look in the scripts menu under partners and I believe it's in the Shaderworks directory-folder for a script that does mass importing of runtimes from older versions of Poser to P9 or PP2012.  I assume you have more then one runtime in P8. If only one that follow the advise above.
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
saibabameuk posted Fri, 14 October 2011 at 12:33 AM
Quote - That method, in essence, is lilnking your P8 library to P9.  It would not be advicable to import all the files within the P8 runtime folder because the Python script for P9 has changed.  Mixing files can potentially disable that function.
No problem in Poser 2012.
