UrbanChilli opened this issue on Oct 23, 2011 · 6 posts
UrbanChilli posted Sun, 23 October 2011 at 8:55 AM
Suddentley I have this odd problem, I can't get transperancy on terrain objects. Even if I try to load the terrain tree and use a new picture on it, the deepest part doesn't become transperant, though it's there if I just load the terrain tree
Hubert posted Sun, 23 October 2011 at 9:53 AM
Hi,
terrain tree?? Transparency?
Do you want to add a texture to a terrain, which uses an Alpha-Channel to mask the transparent parts?
Or do you rather intend to cut off the base of a terrain? If not visible, enable the according bracket-tool in the Terrain Editor (cf my screenshot, that Icon at "1") and then drag the lower bracket end upwards with your mouse (cf screenshot, at "2").
Hubert
"All that we see or fear, is but a Sphere inside a Sphere." (E. A. Pryce -- Tuesday afternoon, 1845)
UrbanChilli posted Sun, 23 October 2011 at 10:43 AM
It's cutting of the base of the terrain, like shown on your picture.
Bryce tree is a terrain object in Bryce 7 Pro
Hubert posted Mon, 24 October 2011 at 4:15 AM
Hi,
sorry, I cannot find that certain terrain in my Preset Libraries?! (Though I have the 7 Pro content installed.)
Can you crop the terrain base, if you create a new empty terrain and draw just some white dots therein?
Suddentley I have this odd problem...
Suddenly indicates, that cropping the terrain worked before, until s.th. occured in your Bryce and/or with your configuration. Have you already tried to close/restart your Bryce or even to reboot your PC? Did cropping work again, afterwards?
Hubert
UrbanChilli posted Mon, 24 October 2011 at 6:51 PM
Hey,
No crop doesn't work, it will always leave a low terrain that fill out the rest. Before I always loaded one of the defaults cropped and imported a png/jpg file and added that and it would work, but for some reason it doesn't work anymore.
This is really fustrating.
Yes, I have tried rebooting. I could make some then it stopped working (I'm making letters after graphic files)
Hubert posted Tue, 25 October 2011 at 3:53 AM
Hi,
am not sure about a possible bug here. Maybe, you should post it at the DAZ Bryce forum. and do . (I do not use my BR7 much, still do most of my brycing in my good old reliable Bryce4. ;)
Maybe, your image's PNG-settings are different, this time??
For a quick test:
- Avoid loading a image file and copy/paste it directly between both applications.
Can you crop it now?
Hint: I often copy/paste directly between my graphic application and Bryce`s bitmap-editor slots. This makes developing a scene/material much faster. And is more convenient than always having to cycle through a complete save/locate/load after each minor image change. ;)
Hubert
