Mariamus opened this issue on Oct 29, 2011 · 4 posts
Mariamus posted Sat, 29 October 2011 at 6:10 PM
Hi,
I have a problem where I've created a neck-prop out of M3's neck to put a new head on M3.
Problem is that I import the neck-prop, line it up and use the "replace bodypart with prop" option.
Then, when I bend the neck or arms, he tears at the seams where the neck meets the chest.
I remember doing this with a neck-stump I downloaded, in order to put V2's head on V3. And I never had any tearing problems there. I know i'm missing something, but what?
amandagirl15701 posted Sat, 29 October 2011 at 10:03 PM
Attached Link: http://www.juno.dti.ne.jp/~yamato-k/Step1.html
Yamato has a tutorial on his site that puts a V2 head on a V3 body. You need to import the head, body and new neck and export the new object under a new name. Then edit a donor M3 cr2 to point to the new object.Mariamus posted Sat, 29 October 2011 at 10:10 PM
Thank you! That was exactly the link I wanted :D
Mariamus posted Sun, 30 October 2011 at 5:12 PM
I have a problem with this, though. I did what was described in the tutorial, but when I load the figure, it doesn't show up. It loads and show up in the hierachy list, but "doesn't exist."
