MacMyers opened this issue on Nov 02, 2011 · 8 posts
MacMyers posted Wed, 02 November 2011 at 7:35 AM
Got image 1
Applied Shape and Texture to figure opted to change face color to match figure.
Got image 2.
Looked in Materials room. Saw image 3. Never had it happen before.
“So, roll me further B_t__h!”
MacMyers posted Wed, 02 November 2011 at 7:36 AM
MacMyers posted Wed, 02 November 2011 at 7:38 AM
vilters posted Wed, 02 November 2011 at 12:09 PM
You have one frontal light up in the sky = way above the figure
This light effect is what you see on your texture
The head should look the same
Also a lot "whiter" on top.
Yiu see the light influence on your texture
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
MacMyers posted Wed, 02 November 2011 at 12:50 PM
I've gone and played with the lights, intensity, position etc. I seem to get four as a default. I can't seem to figure it out but I'll keep messing with it.
Thanks for the tip.
vilters posted Wed, 02 November 2011 at 1:25 PM
Delete alll lights
Put only one infinite light in the scene
The "white" on your texture preview changes as you change the position of the single infinite light.
(Or any other light. Does not HAVE to be an infinite light)
Dev
"Do not drive
Teyon posted Wed, 02 November 2011 at 6:24 PM
That looks like the toon preview. Are you sure you didn't accidentally switch that on? Because if it is on and you delete or add lights, the results will still look toonish.
MacMyers posted Thu, 03 November 2011 at 4:36 AM
I just started over and that worked... so I'm assuming I went HUA somewhere in the process.
I AM having a lot of trouble with lights however (New to Poser).
