Subject: Poser Pro 2012 Crashes during rendering a movie
jaguarmma opened this issue on Nov 10, 2011 · 9 posts
jaguarmma posted Thu, 10 November 2011 at 2:57 PM
I never had this issue with the 2010 version.
What fixes can be made?
jaguarmma posted Thu, 10 November 2011 at 2:59 PM
I have both versions installed.
Does having both interfere with one another?
bantha posted Thu, 10 November 2011 at 4:00 PM
Usually not. There is no service pack yet. When do you have the crashes?
A ship in port is safe; but that is not what ships are built for.
-"Amazing Grace" Hopper
Avatar image of me done by Chidori
jaguarmma posted Thu, 10 November 2011 at 11:40 PM
When I click render movie it gets stuck on frame 1 forever then crashes
CaptainMARC posted Fri, 11 November 2011 at 3:40 AM
I have both versions installed and have no problems rendering animations.
Can you render frame 1 as a picture?
jaguarmma posted Fri, 11 November 2011 at 1:22 PM
It only works with the advanced render settings but the frame rendered doesn't match the camera selected.
CaptainMARC posted Fri, 11 November 2011 at 3:17 PM
Quote - It only works with the advanced render settings but the frame rendered doesn't match the camera selected.
Huh?!
So you select a camera, but something else gets rendered?
And if you don't use the advanced render settings it doesn't work at all?
Have I understood that correctly?
If so, that is very strange. What are your render settings?
jaguarmma posted Fri, 11 November 2011 at 4:25 PM
I get more of a zoomed in affect under the advanced settings method.
I'll try playing with the camera settings
Im at AIPhx right now so I cant access poser =(
wish they had it installed here =( =(
ToxicWolf posted Sun, 20 November 2011 at 11:53 PM
Check this:
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3849777&ebot_calc_page#message_3849777
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
