jaguarmma opened this issue on Nov 17, 2011 · 6 posts
jaguarmma posted Thu, 17 November 2011 at 2:13 AM
Im reading the contents of the reference manual for PP 2012.
I read in the render prefrences section to uncheck the seperate process and adjust the number of threads to a higher number. Which was at 4 threads. So I cranked it up to 18 and I noticed the rendering of a single image was much faster.
If your worried about Poser crashing. Earlier I posted a method that worked on my end to prevent poser from crashing was to open the
Windows Task Manager
Go to View
Update Speed
-Select High
More detail is explained here at the original posting
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2839293
I see no mention of Render Farms.
Is it in the Que Manager section?
I have 2 computers
the one im using now is a windows 7 64 bit
older one is a xp 32 bit
PhilC posted Thu, 17 November 2011 at 2:36 AM
Yes it is the Queue Manager function.
vilters posted Thu, 17 November 2011 at 4:00 AM
A good compromice is to set the threads In General preferences at the double of cores of your cpu.
As PhilC said; Queue Manager manages a render farm.
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
bantha posted Thu, 17 November 2011 at 11:46 PM
I have a quad core, and the speed gain that I get when I go from four to five threads is very, very small. When I switch to six threads, there is no speed gain any more. I would assume that you don't need much more threads than you have cores (virtual cores from hyperthreading included) to get full speed.
A ship in port is safe;
but that is not what ships are built for.
-"Amazing
Grace" Hopper
Avatar image of me done by Chidori.
seachnasaigh posted Fri, 18 November 2011 at 7:04 AM
Only some processors are HyperThreaded; only these will benefit from using twice as many threads as you have cores. The hyperthreads will only run at 2/3 to 3/4 the speed of the primary cores, so you won't double the render speed, but the gain is significant, about 167%-175%.
One of my machines has a Core2 Quad core (not HyperThreaded); it renders best at four threads. Another machine has a core i7 quad (which is HyperThreaded); it renders noticeably faster if set to eight threads.
OSes: Win7Prox64, Win7Ultx64
vilters posted Fri, 18 November 2011 at 7:16 AM
For a quad set it at 4
1 time the cores.
For hyperthreaded quad set it at 7.
8 minus 1 . The 1 being for background process .
Seems to give the best results on most CPU / Systems
Dev
"Do not drive
