Subject: Making Hi-Res renders with Poser???
J10001493 opened this issue on Dec 09, 2011 · 9 posts
J10001493 posted Fri, 09 December 2011 at 3:04 PM
Hi everyone!
Okay, I would like to first off say, I am making a video game using Poser character bases, my own clothing and textures.
Like a real game, I would like to release some renders of the characters.
Now, how can I make some hi-res renders using Poser?
What I mean by hi-res is great quality...
and anywhere in size between 2000-3000 pixels?
I can only get my renders up to a maximum of 1024 x 768 pixels.
Is it possible to get renders much bigger than that?
I am using Poser Pro.
Please help me!
Thank you for your time! >_<
hborre posted Fri, 09 December 2011 at 3:16 PM
There is no such a version as Poser Pro 2008.  The proper name is PoserPro; using the proper name will minimize any confusions and address the appropriate features of your current version for exacting help.
J10001493 posted Fri, 09 December 2011 at 3:19 PM
Quote - There is no such a version as Poser Pro 2008.  The proper name is PoserPro; using the proper name will minimize any confusions and address the appropriate features of your current version for exacting help.
Okay fine, fixed! But can somebody please help me?
jonnybode posted Fri, 09 December 2011 at 3:29 PM
Hi!
Do you look in Render / Render dimensions/ Render to exact resolution, there you can change the size.
J10001493 posted Fri, 09 December 2011 at 3:36 PM
Quote - Hi!
Hi.
Yes, I did try that. I tried setting it to 3000 pixels and 300 dpi, but the render window size decreased to 1010 pixels.
It won't go that high. I wonder why?
Thank you anyways.
vilters posted Fri, 09 December 2011 at 5:26 PM
Please, please, please, give complete and correct info.
What are your system specs?
What version of Poser?
markschum posted Fri, 09 December 2011 at 5:32 PM
You need to use the option to render to exact dimensions and specify the size.
the dpi doesnt really matter , Poser does not use it, photoshop will to determine the print size. You can change it in photoshop.
GeneralNutt posted Fri, 09 December 2011 at 7:33 PM
And note, the preview window doesn't change size when you change the render size, so you will only see part of the render in the preview window until it completes.
IsaoShi posted Sat, 10 December 2011 at 6:08 AM
What Markschum said, plus: *don't* click the button Match Document Window, and make sure the render size is set to Full. This setting is on the top left border of the Render window.
"If I were a shadow, I know I wouldn't like to be half of what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki Murakami)
