MarkR151 opened this issue on Dec 13, 2011 · 2 posts
MarkR151 posted Tue, 13 December 2011 at 10:58 PM
Hi all,
I made my first render last night in DS4, albeit just a test render, but in looking at the various settings under Advanced, I could not find a way to adjust the DPI of the rendered image. Only after I opened it in Photoshop after the fact did I see that the default resolution is 96 dpi. The standard output size, at least in my preferred 3/2 35mm format is roughly 7X10."
I can up the output size of course and did that, but can I up the dpi setting in DS4? In photography & with PS I'm accustomed to working at 300-360 DPI. Would love to keep that for my DAZ renders too.
Any help you can give would be appreciated.
RHaseltine posted Wed, 14 December 2011 at 8:38 AM Online Now!
Actually, DS doesn't set PPI at all - your editor will usually assign either 72 or 96 to untagged images, rather than leave the field (and so the physical size fields) blank. Use Image>Image size, make sure Resample image is unchecked, and enter the PPI you want - as long as you set the pixel dimensions correctly the physical dimensions should now be correct.
