egalps1 opened this issue on Dec 25, 2011 · 13 posts
egalps1 posted Sun, 25 December 2011 at 10:10 AM
Hello and merry christmas everyone
I have poser pro 2010 and i want to do the following:I have some pictures on my desktop jpeg files) and i want to import them in my poser material library in order to use them as textures.Can that be?
Plutom posted Sun, 25 December 2011 at 10:28 AM
Absolutely, but you need an object eg a sphere to activate the Posersurface, then using a texture node import your texture.
Then open your material section and save it....Jan
egalps1 posted Sun, 25 December 2011 at 10:30 AM
Thanks but if you could be a little more detailed.It would be really good...
markschum posted Sun, 25 December 2011 at 10:32 AM
I suggest creating a folder in runtime/textures and putting them there.
Then in Poser use a prop square and create a material for it by adding an image node and connecting it to the diffuse color input of the PoserSurface Node. (the one thats always there)
Then when it looks right save it to folder in the materials library as a material (mt5) .
To do the rest just change the image name on the image node and save it with a new name.
That will give you a material that can be applied to the selected material of anything.
Plutom posted Sun, 25 December 2011 at 10:34 AM
standby with a screen shot, need to set it up
Plutom posted Sun, 25 December 2011 at 10:43 AM
egalps1 posted Mon, 26 December 2011 at 11:04 AM
Thank you all guys.I did EXACTLY what you said and i imported the image i wanted as a material in the material library.However another problem appeared.I wanted to use this image as a picture for a monitor in a poser scene i made (so that the monitor wouldn t be black).However when i try to upload the material on the monitor screen,though it seems that something is happening (the object changes colour when i import the material),when i render it ,the screen is still blank.It has changed colour but it s blank.However when i use this material to some other object it works perfectly.Ok i know that if this happens there s something wrong with the object and not with the material but whyyyyyy does this happen??????Can you help???
Thank you all!!!!!!
Plutom posted Mon, 26 December 2011 at 11:19 AM
The television set, is the screen a separate .obj?
If it is make everything invisible but the screen and tell us what you see. Jan
egalps1 posted Mon, 26 December 2011 at 11:20 AM
Oh one more thing i forgot to mentioned.When i try to upload ANY OTHER material to the screen from the poser library it works perfectly.This makes it a little more comlicated right?
egalps1 posted Mon, 26 December 2011 at 11:21 AM
Quote - The television set, is the screen a separate .obj?
My friend it s just a monitor (a pc screen) NOT a tv set
Plutom posted Mon, 26 December 2011 at 11:25 AM
Hmmm addition, since it changed color, you do have the image on it. On the texture map, adjust the U and V settings to around 200 each and see what you have or change the settings to .5 and see what you have. Yes it is normal, happened to me too.
You may need to play around with the texture map size and see if any change occurs and go from there
egalps1 posted Mon, 26 December 2011 at 11:47 AM
I tried all those you said but NOTHING happened. :(
It s really weird...
100.000 $ TO THE PERSON WHO WILL GET A SOLUTION
Plutom posted Mon, 26 December 2011 at 12:04 PM
Can you give me a screenshot of your materials room with just the TV and screen and node setup?
