3doutlaw opened this issue on Dec 28, 2011 · 3 posts
3doutlaw posted Wed, 28 December 2011 at 3:56 PM
Not sure if that topic even makes sense to what I am trying to understand.
I am working with Dynamic cloth/outfits, and I start at frame 1, add them all, then go to frame 30 and pose the figure, and go to cloth room, run simulation after settings, etc. All is good, good simulation, nice draping, pose, etc.
then i remember that I forgot hair, prop 2, etc...
So i go back to frame 1, add hair, parent it and roll back to frame 30...and it doesnt move with the figure. I suppose that cause it ain't parented in every frame? ...only in Frame 1?
So...the question is how can I setup something in Frame 1 so that it applies across all frames? Thanks!
PhilC posted Wed, 28 December 2011 at 4:11 PM
Once set the parenting will be consistent.
Is the hair a prop or a figure? If a figure you may need to conform it to the base figure rather than parenting and/or pose the hair as required.
3doutlaw posted Wed, 28 December 2011 at 5:21 PM
Its an HR2, and it does not have a conforming option. It just shows a parenting option. I did make some scale and translate changes to the hair before parenting it, but I didn't think that would affect it (using Poser 9 sr1)
