MarkR151 opened this issue on Jan 02, 2012 · 3 posts
MarkR151 posted Mon, 02 January 2012 at 7:55 PM
I have a question about using the DAZ Store supplied Hi-Res Skin Maps & Textures found here: http://docs.daz3d.com/doku.php/artzone/azproduct/3170
In applying the All_NaturalG Hi-Res Skin Map to V4, the round red breast area texture surrounding the nipples is HUGE! Almost the size of her entire breasts, and she has reasonably large breasts. C Cup? So how can I reduce the size or diameter of that area?
I tried selecting just those areas on her breasts in Parameters and they did select the top center parts, but when using Scale, that did not work in reducing them. I'm not trying to reduce the size of her nipples, only the surrounding red area that extends too far beyond the aureola. So what do I do?
jestmart posted Mon, 02 January 2012 at 9:34 PM
If you have the Morph++ set there is an AreolaSize morph. If the areolas on the texture extend to far outside the areola material zone the morph may not help much. On some textures the stretching/shrinking can be quite noticable.
MarkR151 posted Tue, 03 January 2012 at 4:23 PM
I got it working now. Thanks!
