diomede opened this issue on Jan 04, 2012 · 6 posts
diomede posted Wed, 04 January 2012 at 8:45 PM
If I already have a symmetric model in the modeling room, is there a way to use the Construct, add Sphere tabs and still maintain symmetry for the eyes?
ProPose001 posted Thu, 05 January 2012 at 2:00 AM
I am doing the exact same thing. Modeling a character entirely in Carrara. For the eyes I ended up creating a separate vertex object, aligning it carefully and then duplicte the eye with symetry.
GKDantas posted Thu, 05 January 2012 at 5:04 AM
Yes, dont use mesh for the eyes inside the base mesh. If you do that you cant animate it without using ONLY morphs. When you nested a eye ball to the mesh in the Assembler Room, its more easy to control the eye position and move it.
Follow me at euQfiz Digital
diomede posted Thu, 05 January 2012 at 7:53 AM
Thanks. I won't nest the eyes within the base mesh. Eye morphs are vital. Are there other similar best practices.? Teeth? What else?
GKDantas posted Thu, 05 January 2012 at 9:17 AM
In animation we use targets for the Eyes. So you add a Target Helper to point the eyes to the right position, thats why the eye are parented to the base mesh. Morphs in eyes are used to adjust pupil morphs and other things.
If you use to model the eye inside d emesh, you can create one and simple duplicate the mesh, in this case you will need to use bones to animate them.
Teeth can be a mesh inside the base mesh, since exopressions are based in morphs too, so you can adjust the teeths according to the morphs.
UVDan posted Sat, 21 January 2012 at 1:40 PM Forum Moderator
Nice job on the human female model.
Free men do not ask permission to bear
arms!!
