iborg64 opened this issue on Jan 06, 2012 · 6 posts
iborg64 posted Fri, 06 January 2012 at 3:41 PM
Can any one tell me why so many items have no image in the library in poser 2010 ? just installed multiplane cyclorama and a couple of the add ons for it and whilst they work ok i have to add them to a scene before I can see what they are. They all worked ok in poser 8 which I used to use , same problem with quite a few things hair mats are a pain if there is no colour in the description I can not tell what colour it will be untill after its applied. I would say about 50% of the content no longer shows any pics in the library but all of them did in poser 8 (and still do in DAZ studio) Is there anything I can do to put these right ?
SamTherapy posted Fri, 06 January 2012 at 3:50 PM
Take a look at the files themselves and see if there are any .pngs associated. If there aren't, just rsr, there's your problem. AFAIK, Poser no longer converts rsr to png. There's a utility called (I think) rsr2png which will do it for you, though. Run once and you can get rid of the rsrs.
MacMyers posted Fri, 06 January 2012 at 4:28 PM
http://www.renderosity.com/mod/freestuff/details.php?item_id=57197
It is awesome.
“So, roll me further B_t__h!”
iborg64 posted Fri, 06 January 2012 at 4:37 PM
ok found that and downloaded p3do explorer pro to put the plug in in but can not understand how to make it work
MacMyers posted Fri, 06 January 2012 at 4:41 PM
Use the one I gave you. It's simple!
iborg64 posted Fri, 06 January 2012 at 4:42 PM
many thanks for that the converter from this site worked perfectly
