eaglecop opened this issue on Apr 30, 2001 ยท 3 posts
eaglecop posted Mon, 30 April 2001 at 3:25 PM
Why is it that when I make a change to an .obj file in UV Mapper (tuxedo.obj becomes uniform.obj in this case), I save it as a new obj and modify the cr2 file to reflect the same name, I then go into Poser, load the new file, and Poser does not show the "new" clothing (uniform.obj)? Thanks in advance eaglecop
TMGraphics posted Mon, 30 April 2001 at 3:50 PM
Try making a copy of the tuxedo.cr2 and renaming it to uniform.cr2 (or whatever) and deleting the rsr files in the geometries and character folders (poser will remake these when loading the new model) TMG
JKeller posted Mon, 30 April 2001 at 4:07 PM
Remember there are two references to the obj in the cr2. Did you change both of them to uniform.obj?
