Subject: help me with a morph please....
adh3d opened this issue on Apr 30, 2001 ยท 4 posts
adh3d posted Mon, 30 April 2001 at 4:37 PM
I have made a morph in a 3d program of p4nudeman head ( little window in the picture), but when i put it as a morph target for P4nudeman head and i push the dial, the biggest picture is the result, Why? thanks.
adh3d website
JKeller posted Mon, 30 April 2001 at 5:02 PM
Two possibilities: A) the base obj you used to make the morph was not from the P4 nude male, but from the P3 nude male, the business male or casual male. OR: B) something you did in the process reordered the vertices. What 3d program did you use to make it?
JeffH posted Mon, 30 April 2001 at 5:06 PM
You should use the base geometries if possible and not export from Poser.
Eowyn posted Tue, 01 May 2001 at 5:34 AM
Well at least Amorphium Pro creates that kind of a monster effect unless you export the .obj and then import it back to Amorphium. So basically (IF you're using Amorphium), here's what you should do: import that morph .obj back to Amorphium and then export it again. That worked for my morphs. Good luck!
