Forum: MarketPlace Showcase
Subject: Skyreach Pro Clouds
Razor42 opened this issue on Jan 20, 2012 · 16 posts
Razor42 posted Fri, 20 January 2012 at 7:17 PM
Hi,
Thanks for taking a look and your feedback is always appreciated.
Skyreach Pro Clouds is currently under testing and should be released in the next week or two.
Leave a comment if you want to be informed of its release and I'll post a reply which "should" send you a notification.
I've also got some Discount Sales this weekend at MY STORE and combined with the Renderosity Coupon code attached can offer savings of up to %50 Off normal prices.
So have a great weekend!
Regards,
Razor42 aka Castleworx aka Ben
Skyreach Pro Clouds Preview imageSkyreach Preview Panel2PAnel3
Click Link Below to visit my store or see product bundles:
 MY STORE                   BUNDLED SAVINGS!
Razor42 posted Fri, 20 January 2012 at 7:30 PM
How it worksHowsit 2
Howsit3
Razor42 posted Fri, 20 January 2012 at 7:48 PM
another
Razor42 posted Mon, 23 January 2012 at 10:47 PM
Because of the .ppz setup. You will need to Turn shadows off manually on the domes to get true shadows.
Razor42 posted Wed, 25 January 2012 at 11:37 PM
This one is available now at:
Skyreach Pro Clouds
SR Pro
Some notes:
You will need to turn cast shadows of the domes manually. You just need to select the domes when there in the scene and on the Paramaters tab under display turn OFF cast shadows.
Everything will render fine with it on though infinite lights will cast a shadow from the domes when Cast shadows is turned on.
Compatability with The Skyreach moon set you can apply the new clouds to the cloud dome but when you load a moon with the new Skyreach Clouds setup you may see some collision and the transmaps for the moons would need some work to look right on colored skies.
Razor42 posted Fri, 27 January 2012 at 6:29 PM
In relation to the issue with Cast shadow options which may make a scene darker than normal when infinite lights are used. And also cause problems with other shadows.
Its easy to fix with one setting change.
Photobucket
parisgranville posted Sat, 28 January 2012 at 12:25 PM
Thanks Razor42. I have bought all your products and love them. You have anticipated the needs of DS4 users.
Razor42 posted Sat, 28 January 2012 at 5:04 PM
Thankyou parisgranville. I'm glad you like them.
Razor42 posted Sun, 29 January 2012 at 7:35 PM
Skyreach Pro Clouds is currently under testing for use with Reality 2 plugin. I should have some more info abouts its compatibility soon.
One small bug has come to light.
When Unzipping it will generate an error report as some file names have some character symbols which windows doesn't allow. Generally the file will be renamed and as its a non-resource file everything will function as normal with the modified file name.
I will address this in an update soon.
Heres a few more preview images.
PhotobucketPhotobucketPhotobucket
Razor42 posted Mon, 30 January 2012 at 10:17 PM
Good news folks,
V1.1 is on the way.
I've resolved both the zip errors and the cast shadows default now to off.
I'm just waiting to upload the new zip so expect an update email soon.
I can now say it is compatible with Daz 4 and Reality 2.
I'll post some Reality shots soon.
Ben
Razor42 posted Fri, 03 February 2012 at 1:09 AM
Well everyone should of received there update message by now.
And hopefully version 1.1 is running smoothly.
Let me know if you run into any issues with the new version
I'll send out another tip email in the next day or to for those who were interested in receiving more.
I just made up some free poses that will make the moon and the planet pack more compatible with Skyreach Pro clouds.
Both the moon and Planets use a Sky Arc prop where the Planet/moon texture is displayed. The original pose setting collided with the outside cloud layer.
The new Poses fix any collision issues and place the sky arc between the Outer Cloud layer and the background layer.
Some of these will only look good on a dark background because this is how the textures were setup for viewing on a black star dome.
But plenty look great and you can adjust the texture using the Diffuse ambient and opacity settings to more closely match the sky.
The Sky Arch has a spotlight as part of its components you may need to adjust the Intensity of this if there is to much flare on the clouds. Changing the color of the spotlight will also help to blend the planet moon closer to the sky.
So you can just load the sky arc and use the new poses to place it at the right distance between the other objects. I can now say yes they are compatible with a few small limitations.
Get the new Poses here for free
If you have any questions or need any help just PM me or leave a message here.
Razor42 posted Mon, 06 February 2012 at 5:39 PM
New Skyreach Pro Clouds Youtube Video
http://www.youtube.com/watch?v=c-cazxrzRmM
Razor42 posted Tue, 06 March 2012 at 11:32 PM
Skyreach Sun and Clouds on sale now!
Plus great Bundled deals!
See my store for more info.
Razor42 posted Tue, 27 March 2012 at 9:11 PM
Skyreach Pro Clouds is %50 off for the Pot O Gold Sale.
Dont miss out!
Terry Mitchell posted Wed, 28 March 2012 at 4:32 PM
Will there ever be a version for Poser Pro 2012?
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
Razor42 posted Fri, 30 March 2012 at 5:55 PM
Hey Terry,
It would be possible but nothing planned in the near future.
