Subject: problem with rendering hair
mrmagic333 opened this issue on Jan 27, 2012 · 3 posts
mrmagic333 posted Fri, 27 January 2012 at 8:50 PM
Hi All,
can anyone help me fix this issue? The problem is that the hair displays nicely in the preview window, but when I render it with firefly, it doesn't fully show:
preview:
preview window
render output:
render out
thanks
Tools: Poser Pro 2012 64 Bit + Visa/Paypal
RobynsVeil posted Fri, 27 January 2012 at 10:05 PM
I'm assuming Poser Pro of some description? Might want to put Poser version in your signature.
If it is Poser Pro, you need to check your texture files (transparency maps) for gamma settings: should be set to 1.
Search: hair gamma in Poser forum search.
[it is clear that humans have contempt for that which they do not understand]
Metaphor of Chooks
mrmagic333 posted Sat, 28 January 2012 at 1:34 AM
Quote - I'm assuming Poser Pro of some description? Might want to put Poser version in your signature.
ok thanks for the reply. I'm using poser pro 2012 and  changed the gamma as you have stated and it did the trick! Thanks again!
