Subject: Poser 2012 Issue
shorterbus opened this issue on Jan 28, 2012 · 9 posts
shorterbus posted Sat, 28 January 2012 at 4:31 PM
I just made the leap from P8 to P2012, primarily to take advantage of 64 bit, and I'm trying to iron out the bugs and I could use a little (more) advice.
Windows 7.
My Poser 8 is in C:/ Program Files (86) and Poser 2012 is in C/:Program Files.
The p12 library can find and load the P8 runtime stuff, but it will not let me save anything, either in the old P8 runtime or the p2012. In fact, I cannot save anything at all, even stuff I open from the p2012.
To clarify, I load a base v4, add some morphs, a texture, etc., and name her Betty. Then when I try to save that character in the library (any library) i get the message "Warning/cannot open C/Program FIles/SmithMicro/PoserPro 21012/runtime/character/People/Betty
Any help would be much appreciated.
nobodyinparticular posted Sat, 28 January 2012 at 4:41 PM
The content should be in documents, not in the program files with the program itself. Runs afoul with Windows 7's security setup.
shorterbus posted Sat, 28 January 2012 at 5:29 PM
nobodyinparticular, are you sure? I did not have that problem pre p2012. It might make sense having a problem saving stuff from Program Files to Programs Files (86), but I cannot save even to the runtime that came with P2012 which is in the same directory. I could find nothing in the documentation about putting runtime files in the document directory.
DarkEdge posted Sat, 28 January 2012 at 6:06 PM
hmmm, not with me it doesn't run afoul.
P2012 64 bit can install itself in the ProgramFiles folder as you stated, which was determined when you installed Poser (traditional Runtime). I am running Windows 7 x64 bit and install all of my content to the P2012 Runtime. It could be an issue if you aren't running windows a admin.
JimTS posted Sat, 28 January 2012 at 7:00 PM
Look that's a PROTECTED WINDOWS Folder Make a C:Poser Pro2012 Dir and a C:Poser pro 2012 Content Dir then uninstall the earlier Poser set up and Reinstall to the new directories and see if you don't get results
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
moriador posted Sat, 28 January 2012 at 7:12 PM
Just run Poser as an admin.
DarkEdge posted Sat, 28 January 2012 at 7:29 PM
Quote - Look that's a PROTECTED WINDOWS Folder Make a C:Poser Pro2012 Dir and a C:Poser pro 2012 Content Dir then uninstall the earlier Poser set up and Reinstall to the new directories and see if you don't get results
I don't see any peps with guns guarding it...just run your rig as admin and you are good to go.
shorterbus posted Sat, 28 January 2012 at 9:01 PM
Running it as admin did the trick. Thanks!
JimTS posted Sat, 28 January 2012 at 10:27 PM
Quote - I just made the leap from P8 to P2012, primarily to take advantage of 64 bit, and I'm trying to iron out the bugs and I could use a little ........... help would be much appreciated.
Quote - I don't see any peps with guns guarding it...just run your rig as admin and you are good to go.
See Above
Work arounds for user account control abound don't they?
Charles Péguy
