Subject: Clothing: props / dynamic
grahamastor opened this issue on Feb 26, 2012 · 4 posts
grahamastor posted Sun, 26 February 2012 at 3:57 PM
Hi all,
First off - there's an attachment with bondage and nudity with this post - please be advised. Yes I checked the box, no there's no violence but some people have taken offence to bondage in the past, so I'm just being clear.
That all said, often when I see (and buy) clothing props there are usually morphs for different levels of coverage of the clothing; sometimes, but not always there are more than one level of uncovering - e.g. OpenTop, OpenLeft1, OpenLeft2. As can be seen in the attached image the Top is more revealing on one side than the other. As a (beginner) user of Poser do I have to rely on what the creator of the clothing provides, or can I adjust the way the top behaves? Is this what dynamic clothing is for - to allow freedom of adjustment? I've tried using Magnets, but I have to tell you as a beginner they're incredibly difficult to use and often find myself reverting to a saved image over and over every time I attempt to use them.
Thanks for and clarification or advice,
Graham....
hborre posted Sun, 26 February 2012 at 4:39 PM
The description you provide addresses conforming clothing and associated morphs, if there are any available.  Those are inherent to the clothing as the vendor has provided, and you are pretty much bound by those (no pun intended).  However, you can modify those morphs by using the morph brush tool within Poser to make either subtle or drastic changes to the mesh.  Magnetics is another option.  Even taking the clothing object into a 3rd party modelling program could yield better results provided that vertices and mesh are not changed or severely altered.
Dynamic clothing is different, you need to enter the cloth room to apply such clothing to your model, but there is a lesser degree of having it drape as you would like.  The more complex the posing setup, the more frustrating it will be to get the desired results.
grahamastor posted Sun, 04 March 2012 at 4:01 PM
Hi hborre,
    Thanks for the response. I'll be sure to look for conforming clothing with more than one level of morphs.
Graham....
mysticeagle posted Wed, 07 March 2012 at 2:26 PM
dunno if it helps, but i have found that if for instance a dynamic cloth sags in one area or doesnt quite fit snuggly, applying a small windforce with a low spread value can really help push it into those shapes....also scaling the cloth down in size and changing the dynamic settings can be very useful..there's a useful tutorial basic mind you  at
http://my.smithmicro.com/tutorials/2313.html
OS: Windows7 64-bit Processor Intel(R) Core(TM) i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical Processor(s)  6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad day........
Daz Studio Pro 4.5  64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
 link via my artist page
