makis12 opened this issue on Mar 03, 2012 · 7 posts
makis12 posted Sat, 03 March 2012 at 4:04 AM
I tried to open poser pro 2010 yesterday and without reason suddenly it doesn t respond.To be more specific when i double click the icon on my desktop it appears the picture with the woman for a few seconds (as it does always)and after that it opens the library window and that s all.The icon of poser exists at the bottom of my screen (on my start up line) and though it seems as it is normally runing when i click on it ,nothing happens.Poser 6 is perfectly working.Can you help?
Thank you guys
bagginsbill posted Sat, 03 March 2012 at 5:43 AM
Sounds like it is off screen.
Did you have a second monitor plugged in before and now you don't?
Are you on Windows? If so you can "grab" the window as if to move it.
Tap the taskbar button for Poser so it has focus. Then type Alt-Space M Left-arrow
(Hold alt, hit the space bar, release alt, hit the m key, hit the left-arrow key)
You are now moving the window - move the mouse around and see if you can find it.
aRtBee posted Sat, 03 March 2012 at 5:54 AM
I would say:
"without reason suddenly" is not a habit for computers. Did Windows Update installed a new videodriver perhaps? Open Windows Update and look at the history.
Re-installing the Poser software, perhaps? Perhaps something "improved" on the registry.
visit www.aRtBeeWeb.nl (works) or Missing Manuals (tutorials & reviews) - both need an update though
bagginsbill posted Sat, 03 March 2012 at 6:06 AM
AB - he said the library is up - only the library. So it can't be library startup hasn't finished.
SAMS3D posted Sat, 03 March 2012 at 6:09 AM
Look in your task manager and see if it is still on, maybe it never shut off corretly.
Jules53757 posted Sat, 03 March 2012 at 6:56 AM
If nothing works, try the magic of deleting the LibraryPrefs.xml but make a copy of it if you have external runtimes installed. Poser creates a new one but only with the standard runtime plus downloads.
Ulli
makis12 posted Sun, 04 March 2012 at 2:53 PM
Guys i solved the issue by changing the screen resolution.I don t know why,i did NOTHING but i checked it out and it was different than the one i had chosen and i always use.Anyhow everything works fine now.Thank you all for your help!!!
