blueblott opened this issue on Mar 10, 2012 · 5 posts
blueblott posted Sat, 10 March 2012 at 4:25 AM
Hi and hello,
Just an old hobbyist who has got himself stuck, can you help please?
Wheel Rotation...in annimate 2 i created what i thought was a rotation, but instead the wheel turns forward a few frames then reverses direction and turns backwards
So i have a rocking back n forward motion ideal for a rocking chair but not much use for a motorbike Lol.
Started by using the timeline then converted to and imported into Annimate 2.
I downloaded the bike rigged .
So when loaded and both wheels selected i can go parameters drag a Turn slider
and wheels rotate. fine.
Then into Timeline make a rotation (correct forward motion) but when played
rock back n forward??
I also tried the "Rotate Tool" now that will rotate primitives ok as when loaded
the tool centres itself , but for some reason if i were to load a wheel then try the
same thing it wont centre itself?
Sorry to bombard you with questions any help much appreciated.
**Cheers Jon
blueblott posted Sat, 10 March 2012 at 8:31 PM
Hello,
Managed to Rotate my wheel using a primitive cylinder . which the Rotate tool centered
on. parented the cylinder to the wheel,and we have rotation.(one way)Then made the
cylinder opacity zero. Bit clunky but it works LOL!!
Cheers Jon
UVDan posted Sat, 24 March 2012 at 2:09 PM Forum Moderator
Try this in the official AniMate forums for more results.
Free men do not ask permission to bear
arms!!
blueblott posted Sat, 24 March 2012 at 6:18 PM
Thanks UVDan will give it a go.
UVDan posted Sat, 24 March 2012 at 7:57 PM Forum Moderator
You are welcome.
arms!!
