Bendinggrass opened this issue on Mar 12, 2012 · 4 posts
Bendinggrass posted Mon, 12 March 2012 at 8:20 PM
Hello.
I purchased PP2012 during this great sale. I want to know if there is a priority to the order in which I install all the files.
Thanks.
R
WandW posted Mon, 12 March 2012 at 9:13 PM
Presuming you have the Windows version, the main installer will call the content installers (I don't have the install files on this machine, so I don't recall the names offhand). The PDF installation guide should tell all...
"Oh - the manual says that? I have never read the manual - this must be why."Bendinggrass posted Mon, 12 March 2012 at 9:28 PM
Hello. And thanks.
Yes, Windows. Links to all the files were sent to me in an email from SM. There were quiet a few large files that I downloaded. I installed the Installer winzip file which put PP 2012 on my computer. But as there were a number of other files that I downloaded and saved as well, I assume I also open those and install then. As an example, one file is called ReferenceFigures Win. Am I correct in my assumption? I ask because in reading elsewhere I began to suspect the Installer Win file might automatically install the other files I saved. I know, this might sound like a silly idea, but I thought better to ask that go through a load of mistakes setting back everything.
Thanks again.
R
grichter posted Mon, 12 March 2012 at 10:33 PM
What the other files are is the content included with Poser.
I am a Mac user, but do carry a Windows Laptop when I travel vs my Mac Laptop depending on what the tasks are I need to accomplish on that trip...So I am thinking of gettting PP2012 for the win7 machine also and because there are certain apps that are windows only, and I hate running windows in emulation mode on my mac desktop...so been researching the win7 install issues.
Back to the issue.This assumes you are using Win 7. The app goes where your normal apps go in windows. It should have installed the default runtime in your documents folder. Did you or do you find a folder there? The defualt folder name on a Mac is "Poser Pro 2012 Content". Look for a folder by that name or a name close to that in your dcuments folder.
Whatever you do don't put anything in the runtime found in the apps folder where the Poser app is. Win7, won't let you write or change files there. There are other threads that cover this very issue here. Search on this fourm using Win7 or windows7 and you will see all the info as to why.
Now on a Mac when you did the main install of the app you needed to have the extra content you downlaod in the same folder as the installer. When you ran the installer it placed the content automatically in the correct folders. This was covered in the readme and during the install there where check boxes you selected of what you wanted to install. Never tried it anyother way. Not 100 percent sure if the same holds true for the windows installer. Again there should have been a readme that came along with your download. Check that and or the Poser manual which is a PDF and found under the help drop down menu inside of Poser.
Hope that helps and gets you going.
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
