grichter opened this issue on Mar 19, 2012 · 3 posts
grichter posted Mon, 19 March 2012 at 10:09 AM
Airport Security line typical of what you would see in the USA. Queue line for doc check, possible passport prop, podium for doc check person. Tables and conveyors and bins for stuff to go through the carry on scanner. Metal dectector walk thru device and full body scanner.
There are freebee laptops, and placing here shoes in the bin, shouldn't be an issue. Laptop case, spare change and other props you typically palce in the bin, use your imagination.
Thanks for your consideration
Remeber we can't just let Vicki travel anywhere with her sword. Naked for a full body search? Well, she's been their and done that already in more then enough temples so it shouldn't be an issue! :blushing:
Gary
"Those who lose themselves in a passion lose less than those who lose their passion"
markschum posted Sun, 25 March 2012 at 9:26 AM
mrsparky had a freebie set recently.
http://www.poserdirect.com/freebie.html
grichter posted Sun, 25 March 2012 at 10:30 AM
Thanks for the heads up. Will give it a try
Gary
