Forum: Freestuff
Subject: Top Hat?
FranOnTheEdge opened this issue on Mar 19, 2012 · 6 posts
FranOnTheEdge posted Mon, 19 March 2012 at 12:13 PM
Is there a top hat anywhere in freestuff?  One I can use in Bryce?
I can see a nice top hat in the freestuff when I search but on downloading, it was a .pp2 file ending - and Bryce doesn't even see such things never mind import them.
Most of the others are Irish hats, or red and the wrong shape etc.
I also need a dress suit - with tails, but that's impossible. The hat will at least give a better impression than the grey jumper I have at present does...
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
PhilC posted Mon, 19 March 2012 at 12:25 PM
You can load the top hat prop into the Poser scene then export out as an OBJ which I believe Bryce can handle.
EnglishBob posted Mon, 19 March 2012 at 12:27 PM
You can convert a PP2 into OBJ quite easily, even if you don't have Poser. UVMapper can open PP2 files with embedded geometry - it isn't an option on the File menu, but just drag-and-drop the file onto it. Then save in OBJ format which Bryce can open. You will probably have to take care of material settings yourself.
Haha - Phil's top hat beat my bald head. :-)
Xerxes0002 posted Mon, 19 March 2012 at 1:42 PM
You can also grab the free dazstudio (if you haven't gotten the free 4 Pro, hex, updated bryce pro) it will then open the pp2 and can save to .obj.  The newest Bryce and DazStudio 4 has a bridge between them as well.  I haven't used it but that seems to be the way to go.
Xerxes0002 posted Mon, 19 March 2012 at 2:07 PM
I just checked, yup... Load a .pp2 file->send to Bryce... simple and easy.  So if you don't have DS4 pro yet I would grab it while its free.
bobbystahr posted Mon, 19 March 2012 at 6:39 PM
also there's a small app in freestuff caled GeomStripper which will obj a pp2
I see a sound
and try to write it down
Tinkling light sound
The Sun comes up again
