Subject: Remapped Nursoda Characters? Anyone?
pokeydots opened this issue on Mar 19, 2012 · 15 posts
pokeydots posted Mon, 19 March 2012 at 7:55 PM
Has anyone remapped any of Nursoda's characters, to work better with ezskin? Most of them don't have seperate material zones for teeth lips etc.
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
2.80GHz, 4000MHz System Bus, 2MB L2 Cache + 6MB Shared L3 Cache
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
•ATI Radeon HD 4200 integrated graphics
System Ram:  8GB
LaurieA posted Mon, 19 March 2012 at 8:20 PM
That would require adding material zones more than remapping. You really wouldn't need to touch the mapping ;). I might give one a shot, just to see how it goes. :)
pokeydots posted Mon, 19 March 2012 at 8:37 PM
I meant to say adding material zones, I might give it a try tomorrow and see how it goes. If I do this, will I just need to make the cr2 file point to the object with the new material zones for it to work properly?  Thanks :)
System Ram:  8GB
LaurieA posted Mon, 19 March 2012 at 8:45 PM
Quote - I meant to say adding material zones, I might give it a try tomorrow and see how it goes. If I do this, will I just need to make the cr2 file point to the object with the new material zones for it to work properly?  Thanks :)
Yes, use the figure's object file, add the material zones, save under a different name. Copy the original cr2, name it something different and point it to your new object file. Set everything up in Poser and resave to the library.
pokeydots posted Mon, 19 March 2012 at 9:09 PM
Thanks ;o)
System Ram:  8GB
pokeydots posted Mon, 19 March 2012 at 10:10 PM
Anceata-Semil  was pretty easy to add new zones too, Nursoda has everything seperated, so all I had to do was select the parts and add the new material zones :) Hope his others are as easy to do!
System Ram:  8GB
Gareee posted Mon, 19 March 2012 at 10:12 PM
I just got an email there was an update to telka today, FWIW.
pokeydots posted Mon, 19 March 2012 at 10:40 PM
Thanks Gareee :)  I got the e mail too, there were some nice changes to her.
System Ram:  8GB
SteveJax posted Mon, 19 March 2012 at 11:39 PM
Are there plans to update the rest?
Gareee posted Tue, 20 March 2012 at 10:34 AM
Probably.. but since no one has asked him, no one knows.. ;)
pokeydots posted Tue, 20 March 2012 at 5:28 PM
Nursoda has some new freebies at his site :)     http://www.klopfholz.de/
System Ram:  8GB
pokeydots posted Tue, 20 March 2012 at 5:38 PM
Okay, there is a problem when I add the new material zones, when I save the new figure to the library, or as a PZ3 when I load it into poser, it has added back some of the old materials on top of the new ones I made. Now I am stumped on how to do this :(
System Ram:  8GB
SteveJax posted Tue, 20 March 2012 at 8:09 PM
You'll have to edit out the old material zones that you removed from the OBJ from the new CR2 as well.
LaurieA posted Tue, 20 March 2012 at 8:30 PM
Yeah pokeydots, just remove the material zone and all the info for it from the .cr2. Real easy :). Just remember to make a copy of your cr2 before you edit in case you fudge something :P
I've done Eepo. If it ever renders I'll show it...lol.
pokeydots posted Tue, 20 March 2012 at 10:23 PM
Thank you both, I think I got it fixed now :)
System Ram:  8GB
