Subject: Head seam
moldie opened this issue on May 01, 2001 ยท 5 posts
moldie posted Tue, 01 May 2001 at 3:46 AM
I seem to be having a problem with this texture, by the name of Lisa Head. This image is with bumpmapping on, but you can still easily see it without. You can see it even before you render. Is there something I can to to fix this?
Eowyn posted Tue, 01 May 2001 at 5:24 AM
Maybe you should contact the person who made the texture? Although, I don't think that would be too difficult to fix in Photoshop by using the clone stamp tool (or whatever it is called) for example.
br0ken posted Tue, 01 May 2001 at 9:19 AM
the lisa texture has a few of these anomalies. try turning off your bump map to find out if its your bump map or your texture thats the problem. then overlay a transparent uv-map of the female figure overtop of the texture map so that you can see if the texture goes all the way to the edges (i believe i had to fix a few spots on the lisa texture that didnt). if it does, then make sure that the front parts of the texture that map around and join the rear side are the same color at the edges that will meet. if theres a slight change in color/saturation/hue/brightness then you end up with these lines. theyre not hard to fix in photoshop by taking samples with the eyedropper and blending them in.
moldie posted Tue, 01 May 2001 at 11:42 AM
What is the name of the file for the uv-map? Or do I have to purchase it?
moldie posted Tue, 01 May 2001 at 12:44 PM
No wait... I fixed it, using Photoshop. Thanks!
