rondialx opened this issue on Mar 22, 2012 · 7 posts
rondialx posted Thu, 22 March 2012 at 7:18 AM
how can i get high quality renders to upload...i have an image that is 1024 x 530 @512 kb...but keep getting that it violates the upload policys....how do i fix this as i don't want to lower the quality of the image...i have see huge pics on here very well rendered...
Ravyns posted Thu, 22 March 2012 at 7:39 AM
I think the only size limitation is for the thumbnail. Maybe that is what is giving you the error message.
Thumbnails should be ... "min 100 x 100 / max 200 x 200 @ 15kB"
Life may not be the party we hoped for but while we're here we should dance.
archdruid posted Thu, 22 March 2012 at 7:39 AM
try Caesium.. I found it on Source Forge, it's quite good... and free.
http://caesium.sourceforge.net/
I have used it and it's the best I have tried. Lou.
"..... and that was when things got interestiing."
Jack Casement posted Thu, 22 March 2012 at 8:34 AM
I used to have lots of problems with getting the size and resolution of the thumbnails right to stop it being rejected. I now choose the Option of Let Renderosity Create the Thumbnail. End of problems
smithjohanna74 posted Thu, 22 March 2012 at 3:05 PM
Attached Link: http://www.gorgeousjewelrydeals.com/Sterling Silver Necklaces
Same with me, the usual problem is the resizing of the images.smithjohanna74 posted Thu, 22 March 2012 at 3:06 PM
Quote - Same with me, the usual problem is the resizing of the images.
karl.garnham1 posted Fri, 06 April 2012 at 5:02 AM
Assuming you use Photoshop and have a document size limitation try this
open you image in Photoshop and then go to the image tab and choose resize image size and then untick the resample image button and in the resolution put this size in 30000(just the number) pixels per inch then tick resample image and resize to the number you need and choose this option from below Bicubic Sharper (this is best for reduction) and you image should be at is best save it either as a .jpg or even better .png file (I don't know if renderosity accepts .tiff files but if they do use a .tiff as this will make it even better than a .png
Hope that has helped you
Regards
Karl
