Subject: Upload size of pic
beos53 opened this issue on Mar 29, 2012 · 7 posts
beos53 posted Thu, 29 March 2012 at 11:39 PM
I haave tried to upload a picture to the forum using several sizes, etc and I keep getting this
"There was an error uploading your file. Your message was saved without it. Your file exceeds the maximum file size limit. "
I have hunted and cannot find the correct specs for the upload
What is the correct size
Thank you
Steve
PoserPro 2014, Windows 7, AMD FX-6300 6 core, 8 GB ram, Nvidia GeForce GTX 750 Ti
BionicRooster posted Fri, 30 March 2012 at 12:16 AM Forum Moderator
I think it has to be under 256kb.
Resolution doesn't matter.
Poser 10
Octane Render
Wings 3D
beos53 posted Fri, 30 March 2012 at 12:22 AM
thank you for the info
MacMyers posted Fri, 30 March 2012 at 4:37 AM
It's 512 kilobytes.
You can typically keep the image size the same if you save as a .jpg and then save at 90% or whatever it takes to get the image under the limit.
            “So, roll me further B_t__h!”
hborre posted Fri, 30 March 2012 at 9:27 AM
Or save the image for web in a 2d program where you can control the quality.  By inputting the max size, the image will be automatically set to the correct quality.
KimberlyC posted Fri, 30 March 2012 at 9:39 AM
Yep .. I'd "save for web". That should be the easliest for you. :)
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
lmckenzie posted Sat, 31 March 2012 at 8:20 AM
If you're on Windows, you can use RIOT or Interactive JPEG Optimizer. They're handy when you don't want to fire up an image editor like PhotoShop. RIOT also works as a plugin for a couple of iname viewers.
http://luci.criosweb.ro/riot/
http://www.photo-freeware.net/interactive-jpeg-optimizer.php
