JAFO opened this issue on Mar 31, 2012 · 61 posts
JAFO posted Sat, 31 March 2012 at 4:48 PM
i have nearly finnished a hair style i like but when i do a simulation it goes nuts, i have used cage's bake script, have everything locked in where i want it ,but when i run a simulation it gets all kinky, way over-active.. are there settings that can calm this down and still retain the collision settings?....i have searched all day here and at dna but only find things pertaining to styling hair not animating it...i have tried every combination of settings i can imagine... im beginning to wonder why its called dynamic hair if you cant simulate dynamics with it..have i wasted my time with this? sure it looks good in the initial pose but i cant imagine spending all this effort for a one-image prop that cant pose or animate... thanks for any help...
i have a sim running now , ill post a pic afterward...
:O)
Y'all have a great day.
RedPhantom posted Sat, 31 March 2012 at 5:14 PM Site Admin
Without seeing your scene I'm guessing but it sounds like you have strands that are intersecting the skull cap prior to the sim starting.
JAFO posted Sat, 31 March 2012 at 5:50 PM
i was very carefull to avoid intersections when styling but there are a lot of guides involved , may have missed a few ,any tips on finding and fixing this prob?... there are 13 groups , when i ran cage's bake script the hair changed, kinda jumped a distance off the prop and had to be repositioned , this may have caused intersections though the before and after renders looked very much the same... thanks for responding im kinda lost trying to consider all the variables involved here... my biggest concern is that im worried there arent any settings that will reasonably simulate hair even if i get a perfect model built , i have been testing settings with an animated sphere prop with just a few hairs on it and still get either 'wild hair' or collisions arent working very well , have i just not found the right gravity/spring/dampening combination that works? or are there such settings ?i have seen hair videos that looked great,(such as the beautifully done video by toxicwolf which inspired me to give poser hair another shot), but only in distant renders where there wasnt any real detail to consider...
thanks
:O)
wimvdb posted Sat, 31 March 2012 at 5:55 PM
Most of the time when this type of jumping occurs bend resistance is too high. Have you tried setting it to 0 and see what happens?
JAFO posted Sat, 31 March 2012 at 6:06 PM
Quote - Most of the time when this type of jumping occurs bend resistance is too high. Have you tried setting it to 0 and see what happens?
actually no, i tried setting it higher a few times but didnt like the results and reverted back to the default, ill try 0 and see what happens, i find most of the settings i try have exactly the oposite effect than i was expecting, i have done hair with halfway decent results in max, i suspect poser settings may be the reverse of max..., im not sure.
Thanks
:O)
JAFO posted Sat, 31 March 2012 at 6:12 PM
heres the video by ToxicWolf i referred to earlier... http://www.youtube.com/watch?v=po5EF1PwtXs ..., i find it fasinating, this guys got it together ....
wimvdb posted Sat, 31 March 2012 at 6:25 PM
Getting to know what the parameters do is the biggest hurdle. The other thing is to understand the difference between styling and dynamics. Styling control how the hair looks when nothing influences it. The dynamics control which influence and how much of it - this is resistance from the hair itself (bending resistance, stiffness, etc) and the environment (gravity, air resistance, etc).
I have seen a good hair tutorial in the past, but I can't find it anymore. Most tutorials give you a step by step instruction and do not go into what the parameters actually do and in which order you should use them. That is one reason why it is difficult to get good results.
Best thing to do is to play with a ball and turn each dial seperately to see what actually happens. Do not forget to turn on collisions since that has a big impact
I find the styling the most difficult part because it is pretty unforgiving regarding mistakes. I hope this will improve in the next release
RedPhantom posted Sat, 31 March 2012 at 6:59 PM Site Admin
the jumping from cage's script seems to be caused by the skullcap not being in zero position. If you move it to that before running the script, you should be ok.
here are some explainations of the settings http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3881067&ebot_calc_page#message_3881067
There's not specific numbers to set things at but help understanding them.
RedPhantom posted Sat, 31 March 2012 at 7:02 PM Site Admin
Also with hair it's a good idea to save often. It's easy to wipe out all your work with a click of the button.
JAFO posted Sat, 31 March 2012 at 7:34 PM
you guys are great your patience is greatly appreciated, if im slow to respond forgive me i have half a dozen tabs open here trying to absorb as much as possible...sometimes i get fixated on something and look up and its hours later....lol
:O)
RedPhantom posted Sat, 31 March 2012 at 8:32 PM Site Admin
Don't worry about slow responces. We all understand things take time and poser sometimes has to take a back seat to real life.
JAFO posted Sat, 31 March 2012 at 9:28 PM
so its ok to drape hair as an initial styling then use the bake script to lock it down? im still seeing the displacement when baking after affirming it is centered, i may need to try a diff skullcap this one is slightly off center by default,the origin is visibly off center form the geometry no idea why that is...it was free so i have no complaints, ill take it into max and center the origin and try it again
interresting side note: ever use the morph tool to style and smooth with? then bake the verts and delete the morph?...it seems to work pretty well fast and accurate, easy to make curls and waves, no effect on the simulation at all that i can see. hell of a lot easier than trying to drag hair around by the end verts, just put the end where you want it and smooth the remainder into place... ill have to play with this more later, im testing this on my hair ball prop btw...
im running on less than an hour of sleep in 2 days... can you tell? i tend to start babbling ...lol
:O)
JAFO posted Sun, 01 April 2012 at 2:25 PM
heres an initial render and a short clip i made last night after redoing the hair, i recentered the origin on the skullcap and it still had the same problem with the bake script, so i abandoned the skullcap and created the hair directly on the head(i know this is a no-no) but the results were the same still jumping when baked, perhaps i dont have the latest version of cages script , i dont know...(i was up untill 4:30am)
anyway i quickly re-created the hair, using an initial drape/bake/morphtool styling/bake/used the hither dial on the camera with backfacing polly's enabled to look inside the model to find and fix any intersections(only a couple easily smoothed to outside the body with the morph tool) rebake again/reposition/double check for penetration/add bvh motion quickly bent arms to cover a prominent breast morph for youtube/simulate using default settings except bend resistance set to 0 and collisions enabled both in hair and body/render....
overall not so bad other than its still way too lively, the bangs i can just dial back on the dynamics paramater as theres no real collision issues, but the hair that drapes over the shoulders penetrates if i change the paramaters... so im still in the same basic boat i was in yesterday.... tweak and retest.... i really appreciate you guys offering advice and hope more suggestions are forthcomming... its such a privlage to be part of a community where you can openly share ideas and people are so giving of their time and experience, too bad it doesnt extend more into the 'real world' ...
again and as always ...thank you...
:O)
ps: forgive me my spellcheck isnt working in firefox... :O(
mysticeagle posted Sun, 01 April 2012 at 2:59 PM
looking really good jafo, how are the render times for the hair?, i haven't tried dynamic hair for a few weeks, but now ive got my faster machine i might have another go, although in the past homemade hair has always caused my system to freeze up lol
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s) 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
link via my artist page
RedPhantom posted Sun, 01 April 2012 at 3:06 PM Site Admin
How do you use the morph tool? When ever I try to use it on hair the highlights bounce around like a jumping bean on steriods. I start on an end move half an inch and the thing is on the roots half a skull away.
JAFO posted Sun, 01 April 2012 at 3:18 PM
Quote - How do you use the morph tool? When ever I try to use it on hair the highlights bounce around like a jumping bean on steriods. I start on an end move half an inch and the thing is on the roots half a skull away.
yes this is a major issue, but with patience you can get it to settle where you need it, i work around this by changing camera position or zoom, the morph tool is not designed for this purpose, perhaps cage can port it to the hair room and work out the kinks for us(hint,hint)the tools are already there , just needs a true wizzard to iron out the bugs... cage and shvrdavid are true gods when it comes to programming, oh and lets not forget about BB and Phil i stand in awe of their accomplishments...
dont give up you will quickly get the hang of it and wonder why anyone would do it any other way, it soooooo simplifies the process, and you can get the results you want instead of settling for 'thats the best i can do with what i have to work with'...
:O)
JAFO posted Sun, 01 April 2012 at 3:28 PM
Quote - looking really good jafo, how are the render times for the hair?, i haven't tried dynamic hair for a few weeks, but now ive got my faster machine i might have another go, although in the past homemade hair has always caused my system to freeze up lol
the render is averaging around 1min 45sec per frame but keep in mind this is 720/480 frame size.... sim time is comparable... im running AMD FX-6400 6core processor with 15gb RAM... just eliminating antivirus and networking(networking stopped because theres no antivirus) from my system shows about a 30% increase in overall performance( this is my personal observation, i am not a computer wiz, and i am not recomending this for everyone)...
:O)
RedPhantom posted Sun, 01 April 2012 at 7:13 PM Site Admin
I'll keep trying. The more tools I have under my belt, the better hair I should be able to make. I've got cages hair to path script and I've getting the hang of the translate hairs tool in the hair room. I figure in about 3 or 4 years I should be skilled in all of them. Maybe it'll go a little fasted with my new computer. Poser is running so muh more smoothly.
JAFO posted Sun, 01 April 2012 at 7:58 PM
i downloaded the hair to path script but havent had a chance to check it out... the morph tool is alot better than it was in pp2010 i find that using smaller brush sizes, lower stregnths and slow movements are best ... im still changing prams and running sims , getting better results, but not quite there yet.... im also finding that its easier if you start with like 10 verts get those roughed in /double the verts smooth and adjust and repeat untill you reach about 100 it goes pretty fast... seems i can do about twice as much in half the time doing it this way. once i get the prams worked out i think we have this whipped...
oh another note : im getting to a point at times when the morph tool stops working at all.... running the bake script aleiviates this and everything works properly again... maybe the cache gets full and baking clears it?
:O)
mysticeagle posted Mon, 02 April 2012 at 7:05 AM
this is probably another of my out of the box observations, but wouldn't it be idea if there were a skull cap prop that had the hair zones predefined, top,bangs,side etc so that you could just go into the hair room and tweak the settings to suit your own needs?, i don't know if it is even possible, but i find tbh, the hardest part of the hair room is setting the hair groups onto the skull cap.......
day........
Carrara beta 8.5
maker
My freestuff
Photopium posted Mon, 02 April 2012 at 9:35 AM
Okay, I've spent an hour searching...where is Cage's Hair baking script? Thanks :)
mysticeagle posted Mon, 02 April 2012 at 10:11 AM
is it this one ?
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2798819&page=18
day........
Carrara beta 8.5
maker
My freestuff
Photopium posted Mon, 02 April 2012 at 10:54 AM
That's not the one. Thanks though
RedPhantom posted Mon, 02 April 2012 at 10:58 AM Site Admin
Quote - is it this one ?
No that's the hair to path scriptthe deformation baking is here
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2839086&page=3#message_3861962
JAFO posted Mon, 02 April 2012 at 11:33 AM
Quote - this is probably another of my out of the box observations, but wouldn't it be idea if there were a skull cap prop that had the hair zones predefined, top,bangs,side etc so that you could just go into the hair room and tweak the settings to suit your own needs?, i don't know if it is even possible, but i find tbh, the hardest part of the hair room is setting the hair groups onto the skull cap.......
this would be great to have , though i dont think a single speciffic grouping would cover many of the hundreds of hairstyles people would want, but a basic grouped cap would be usefull...more advanced styles would need more advanced skills, and people with these abilities could easily make their own groupings...
:O)
JAFO posted Mon, 02 April 2012 at 11:48 AM
its encouraging to see that people are interrested in this topic and eager to discuss and advise , the more we discuss the more we learn AND the more we send a message to the developers that we need more tools and better defined code, my observation is that they are watching and they DO pick up on cues and go in the direction we steer.. i think they go in the direction of the most interrest, long active discussions pull more weight than short undefined complaints IMHO....i think the hair and cloth rooms are more or less in the beta stages and we need to test and make recomendations as to what improvements are needed to make them viable and fully functional .
:O)
Photopium posted Mon, 02 April 2012 at 11:52 AM
The bake script isn't working for me...
Whether I use styling tools, bake, then drape or whether I drape, bake, then style...it's still resetting the hair.
Am I not understanding what this script is for?
JAFO posted Mon, 02 April 2012 at 12:09 PM
i think... and its just personal observation... simulation is a seperate process to be done after styling is completed and is controlled by the simulation settings, simulating to get initial drape seems to be helpfull, though it does tend to complicate styling as the strands all settle together and are hard to seperate for individual shaping, using large groups also complicates things IMHO, smaller groups are easier to control and lead to finer detail....
heres an example: its better to make a group that drapes in front of the shoulder and a seperate group that drapes behind, because when interpolation occurs (show populated ) the interpolated strands go through the shoulder and doesnt look very good ,seperating the direction prevents this, the same applies to hair parting you need a left and a right or whatever .... after shaping use the bake script to lock everything into the initial state and if you leave the hair room and use the morph tool to better define shape and detail , bake again and delete the morph created by the morph tool( if you dont delete the morph the morph is added to the new shape)
im finding styling to be the easy part, the devil is in the simulation settings....
:O)
JAFO posted Mon, 02 April 2012 at 12:59 PM
im not having the problem with hair jumping off the surface after baking with other items only the one skullcap and the figure im working with, i think the problem with the figure is that its heavily morphed and perhaps i need to zero the figure and bake the head , its worth a try i guess...
Cage posted Mon, 02 April 2012 at 1:21 PM
The baking script works on any current actor, not just hair. The script alters sets the base shape of an actor to match the deformed shape of that actor at the time the script is run. So if you take M4's head, make him smile, then run the script on the head, you'll get a head that can only stop smiling if you set the smile morph to -1.0.
When used on dynamic hair, it does seem that there can be some complications, but these lie not with the script but with some oddity in how Poser handles dynamic hair. As far as I can tell, any script which processes hair will do this. If the hair or its parent (skullcap) have any transforms applied, the hair will seemingly jump to its default worldspace position rather than its default localspace position (relative to its parent). That's my only guess for the described error. The workaround would seem to be to avoid running any scripts on dynamic hair which is not in its default position. Zero all the transforms on the hair and its skullcap and all actors all the way up the actor chain until the hair is where it would be if its skullcap were not parented to anything.
Cage can be an opinionated jerk who posts without thinking. He apologizes for this. He's honestly not trying to be a turkeyhead.
Cage had some freebies, compatible with Poser 11 and below. His Python scripts were saved at archive.org, along with the rest of the Morphography site, where they were hosted.
JAFO posted Mon, 02 April 2012 at 1:43 PM
thank you cage for clarifying this ,this script is a welcome addition to my toolbox , well developed and tested , now i just need to pay more attention to where i put the read-me's....lol
:O)
JAFO posted Tue, 03 April 2012 at 1:07 PM
i zero'ed the body using the joint editor and ran the bake script on the head and the hair got really screwed up... but guess what?... i reset all the transforms on the hair and everything popped back into perfect allignment... i love this script ,cage is a godsend...whoda thunk?.... now if i can just figure out this dynamics issue....the problem is the long drapes of hair over the shoulders , the rest can be calmed down using the dynamics paramater dial for each hair group, i have run tests on a ball prop having it colide with a cylinder prop and get settings that work pretty well with this set of props, but when i transfer the settings to the actual figure they look completely different, im thinking it may be too many collision poly's for the simulator , i think ill try making a lower rez proxy for the collisions and see what happens ...
:O)
MistyLaraCarrara posted Tue, 03 April 2012 at 1:51 PM
Quote - so its ok to drape hair as an initial styling then use the bake script to lock it down? im still seeing the displacement when baking after affirming it is centered, i may need to try a diff skullcap this one is slightly off center by default,the origin is visibly off center form the geometry no idea why that is...it was free so i have no complaints, ill take it into max and center the origin and try it again
:O)
you mean, the morph tool instead of the styling tools?
JAFO posted Tue, 03 April 2012 at 2:17 PM
i mean, do an intial styling with the styling tools and then leave the hair room and use the morph tools to finish styling( i use the smoothing and the push pull tools in screen mode at low stregnth), then use cages bake script to lock everything down with, it works very well and doesnt seem to affect dynamics...if you mess up and wish to restart just return to hair room and regrow the hair and try again, you can return to the hair room at any time BTW...it takes a few min to get used to using the morph tools on the hair as it isnt designed for this purpose but with patience you will get good results... keep in mind this is experimental and hasnt been thoroughly tested, but innitial results look pretty promising...
:O)
mysticeagle posted Wed, 04 April 2012 at 8:12 AM
what is the secret to selecting the hairs with the styling tool?, i find for example if i use shrvdavids high res cap and just create say 6 hair groups on it, when i select the styling tool the select hairs button stays illuminated but the other buttons are locked, if i click around randomly for a bit, it seems to eventually decide to let me style "some hairs" but not neccesarily the ones i wanted lol
day........
Carrara beta 8.5
maker
My freestuff
JAFO posted Wed, 04 April 2012 at 9:02 AM
i drag a selection box around the guides i wish to work with... make sure you dont have 'show populated ' checked when styling as it can be confusing which are the guides and which are the hairs...and it eats resourses and slows down the process... i find it best to work with small selections, i usually make the hair a bit longer than needed and only worry about getting the tips where i want them and leave the hair room and use the morph tools to smooth the rest into position then return to hair room and work with another selection...IMHO shvrdavids high rez cap is much higher rez than needed, he has a lower rez version that seems adequate for any med to long hairstyle... i may use the hi rez for short hairstyles like crewcuts or buzzcuts ...
:O)
JAFO posted Wed, 04 April 2012 at 9:50 AM
im not having too much luck with the dynamic settings, it seems no matter what i do its over-active... looks fairly good from a distance but up close it looks like crap..... just for giggles and laughs i extended my frame range and retimed the animation to run at half speed then resimmed ,and rendered every other frame to avi to get it back to the original speed.... it looks twice as good but still is a tad too active... im thinking about tripling the frames just to see the results... it is a lot of sim time but if the results are good it may be a workable solution (for me) i dont think most people would want to go to these extents for animations but it may be all i can offer for now, besides most people render stills and the only sim would be to get from the default pose to desired pose and only rendering the last frame, so i may recommend simming 10 or more frames to get positioned then an additional 10 or more frames for settling...sim time for me is a tad over a minute per frame..i have known artists to go to greater lengths in their quest for better results... in the past it wasnt unusual to wait days for one frame to render...
:O)
JAFO posted Sat, 07 April 2012 at 11:40 AM
:O)
RedPhantom posted Sat, 07 April 2012 at 1:46 PM Site Admin
I'm gonna have to try that later. Have to go to an Easter dinner at my in-laws. I'd rather stay home and use Poser. Shoot I'd rather reinstall everything in my runtimes.
JAFO posted Sat, 07 April 2012 at 4:45 PM
Quote - I'm gonna have to try that later. Have to go to an Easter dinner at my in-laws. I'd rather stay home and use Poser. Shoot I'd rather reinstall everything in my runtimes.
LOL...good luck
im getting beautiful results with styling long hair but getting nowhere close to acceptable dynamics ... such a pitty
with short hair i can just turn the dynamics down and it works fine....
:O)
RedPhantom posted Sat, 07 April 2012 at 6:04 PM Site Admin
I wonder if the morphs are messing up the dynamics. I don't do alot of simuations. I had good luck with this one. The woman's hair was dynamic. I had her moving like she would have been if she was running and then ran the sim and rendered one frame.
I tried a sim of my pigtails and they wouldn't bend properly. I did use amorph on the pigtails. I know 2 sims isn't much to go on, just a thought.
RedPhantom posted Sat, 07 April 2012 at 6:11 PM Site Admin
JAFO posted Sat, 07 April 2012 at 7:14 PM
it could be that the morphs have some effect, but i have been baking after morphing and deleting the morphs ... i guess it could have an unexpected effect tho, i dont know.
i have been simming on a low rez prop without any morphs...just baking..and seeing pretty much the same hyperactivity....didnt poser previously have a button to disable self collisions? seems if you enabled self collisions everything went bezerk....i think this may be the main problem, im seeing activity where the hair isnt touching anything other than itself... i also think there needs to be more user controlable settings like sim steps. and i also think the ability to make and reduce keys would go a long way toward better realism...
i just tried simming on an unmorphed section of hair on my model and i am getting exactly the same results so i doubt its morph related... im suspecting the simulation in poser is just not adequate for this long hair and needs more development.
im wide open if anyone wants to suggest settings... ill try anything...lol
:O)
JAFO posted Sat, 07 April 2012 at 7:42 PM
i have been scanning the archives here at Rosity and seeing pretty much the same frustration all the way back to poser 5 when dynamic hair was introduced... things have shown improvement but theres a long way to go before this dynamic hair is fully usable.
is there any way to export dynamic hair that works...is there a converter out there ?
:O)
RedPhantom posted Sat, 07 April 2012 at 8:04 PM Site Admin
Export it? You mean like an obj?
JAFO posted Sat, 07 April 2012 at 8:36 PM
yes to .obj exporting from poser doesnt work ...it would have to be converted somehow...i saw a thread somewhere that mentioned it but cant find it now. a py script i think
if i could convert it i would just make it into a fig
:O)
JAFO posted Sat, 07 April 2012 at 8:39 PM
would be great if we could just kill the dynamics and just have collisions and gravity working, they seem to work fine
RedPhantom posted Sat, 07 April 2012 at 9:00 PM Site Admin
I have a script called hair_to_prop that I believe does that. It's been awhile. I'll test it once the simulation I'm running finishes.
JAFO posted Sat, 07 April 2012 at 9:08 PM
im running a sim with no styling at all(default settings 20 verts per hair hair length at 1) letting hair just drape and sim, no movement at all, still seeing large amounts of activity, so its not the morph tool nor the bake...
:O)
JAFO posted Sat, 07 April 2012 at 9:10 PM
getting no hits in search of rendo with hair_to_prop going back 20 yrs
RedPhantom posted Sat, 07 April 2012 at 9:16 PM Site Admin
Keep in mind if you do get it converted, it's gonna have a ridiculously high poly count.
RedPhantom posted Sat, 07 April 2012 at 9:45 PM Site Admin
ok the hair to prop was a misnamed script. I know I just saw it on my computer with in the last week. It's gonna drive me nuts til I find it.
JAFO posted Sat, 07 April 2012 at 9:49 PM
Quote - ok the hair to prop was a misnamed script. I know I just saw it on my computer with in the last week. It's gonna drive me nuts til I find it.
lol ...hate when that happens
i may have it someplace and just never used it...usually grab everything thats offered...
:O)
JAFO posted Sat, 07 April 2012 at 10:03 PM
ok what i have is called DynamicHairConverter... ill try it and see what happens
:O)
JAFO posted Sun, 08 April 2012 at 11:41 AM
i set my frames at 1000 and let the sim run during the night with no movement of the figure and the activity continued throughout the simulation, seems there would some point where the hair would 'settle' and cease movement, i find this isnt the case...
:O(
RedPhantom posted Sun, 08 April 2012 at 2:33 PM Site Admin
I've been trying that today. The hair I was using continued to move slightly. If I put the air dampening to .2 it decreased to just a twitch. The hair moved pretty nicely too. I left the rest of the settings at default. I'm gonna see what another hair does next.
JAFO posted Sun, 08 April 2012 at 5:30 PM
cool.... thanks for the help
im working on another experiment and so far it looks pretty good... ill be posting another animation later, probably tomorrow... give you a hint... i tried to lead the community in this direction in 2000 but the nay-sayers won the argument...lets see if anyones ready to listen...
:O)
JAFO posted Sun, 08 April 2012 at 5:37 PM
oh btw i couldnt get that Dynamic Converter to work ,all i managed to do was import the skullcap ...
RedPhantom posted Sun, 08 April 2012 at 7:31 PM Site Admin
Yeah I couldn't get the converter to work either. I got the strands imported but they didn't render.
The other hair I tried bounced around like crazy and didn't settle. There was collisions on it with the model. when I put the model into a pose where the hair didn't touch the model it settled to the slight twitching I had with the previous hair tests.
JAFO posted Tue, 10 April 2012 at 12:40 PM
sorry but there seems to be a bug in pp2012 in the sims ,i saw in another thread that this is a known bug and addressed in the next SR...whenever that comes out ill continue this test... this is becomming a real PITA... guess ill just work on one of my other proj's in the meantime..
:O(
RedPhantom posted Tue, 10 April 2012 at 6:41 PM Site Admin
I was wondering if it was. Thanks for posting.
