marvlin opened this issue on Apr 06, 2012 · 8 posts
marvlin posted Fri, 06 April 2012 at 8:29 AM
Hi guys, I am playing around with Superhose by Bice and Outoftouch and have come across this wierd effect that doesn't look right.
The superhose have been weightmapped as is the figure they are on V4.2
This was rendered in firefly with gamma correction turned off.
I also used EZskins free skin application on the Vicky figure.
Any ideas what it is and how to get rid of it?
Thanks
Marv
i7 5930K 3.60Ghz | ASUS X99-S Motherboard | Crucial Ballistix Sport 32GB DDR4 2400MHz RAM | NVIDIA TitanX | Antec 1000w Power supply | Windows 10 x64 Home
mysticeagle posted Fri, 06 April 2012 at 8:31 AM
i think i had this in my last but one image in the gallery, try scaling the stocking up just a touch, that seemed to get rid of it for me
OS: Windows7 64-bit Processor Intel(R) Core(TM)
i5-2430M CPU @ 2.40GHz, 2401 Mhz, 2 Core(s), 4 Logical
Processor(s) 6GB Ram
Poser: Poser Pro 2012 SR3.1 ...Poser 8.........Poser5 on a bad
day........
Daz Studio Pro 4.5 64bit
Carrara beta 8.5
Modelling: Silo/Hexagon/Groboto V3
Image Editing: PSP V9/Irfanview
Movie Editing. Cyberlink power director/Windows live movie
maker
"I live in an unfinished , poorly lit box, but we call it home"
My freestuff
link via my artist page
snakegrab posted Fri, 06 April 2012 at 8:38 AM
I've seen this as well with tight fitting translucent clothing and specifically with Superhose. A quick fix is to turn of "Visible in Raytracing" for the figure i.e. the stockings.
marvlin posted Fri, 06 April 2012 at 9:37 AM
Thanks guys the turn of visible in raytracing worked like a charm.
I love this forum :o)
Winterclaw posted Fri, 06 April 2012 at 11:34 AM
You can also try magnitizing the item for a better fit. Also, this is just a huntch but lowering your ray bias might also help.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
marvlin posted Fri, 06 April 2012 at 11:57 AM
Quote - You can also try magnitizing the item for a better fit. Also, this is just a huntch but lowering your ray bias might also help.
Okay thanks, I'll give it a go. Never magnetized clothing before I'll have to see if there is a tutorial, sounds good though.
Also on the same figure. Any ideas on what is causing the effect in the above image?
Once again I'm using EZskin with the "Final" settings and baggins subscatter trick set to on.
Thanks again and sorry for bombarding you guys with this stuff :o)
hborre posted Fri, 06 April 2012 at 12:15 PM
Nasty looking rash!! Try using EZskin without the BB trick. That was predominantly created for the bluishness around the mouth and eyes due to low scaling settings on the SSS node.
WandW posted Fri, 06 April 2012 at 12:24 PM
Quote - You can also try magnitizing the item for a better fit....
V4WM has no magnets in the legs; only in the chest area...
