asmith opened this issue on May 01, 2001 ยท 6 posts
asmith posted Tue, 01 May 2001 at 7:38 AM
Hi guys, been a member forever, but this is my first post in years. I am trying to create a prop of a sculpture. I am using a figure to do this, when I save it in obj format and bring it back in to poser when I click on render materials it still shows the seperate body parts for texturing, how can I get it to come back as one object so I can apply one texture, not just the same texture for the seperate body parts? The way it is now the texture is not uniform through the whole object..............Thanks
Wizzard posted Tue, 01 May 2001 at 7:55 AM
export it as a 3ds... that way tis all of a piece..... then re-import is into POser.. and material away.. at least it usually works for me 8 ) Cheers
asmith posted Tue, 01 May 2001 at 8:47 AM
First off thanks for your quick responce, I have tried this and it does spreads the texture over the entire prop, which is good. However with the object in the window when I click on render materials then materials it still shows all the seperate body parts, although not a big deal, it shows the characters name and as a prop I would like it not to be that specific. Is it possible to eliminate that? ................Thanks again
Wizzard posted Tue, 01 May 2001 at 10:30 AM
easy enough.... open the heirarchy rename the prop... hrmmmm.. I"m trying to remember if I pulled the 3ds into another programme and reassigned the mats... I may have... but it should come in all of a colour and applying the mat to all should give full coverage... Cheers
asmith posted Tue, 01 May 2001 at 1:27 PM
Thanks Wizzard, that seem to do the trick...Asmith
Wizzard posted Thu, 03 May 2001 at 12:16 AM
you're welcome 8 )
