cspear opened this issue on Apr 18, 2012 · 23 posts
cspear posted Wed, 18 April 2012 at 12:25 PM
So I tried making my own, and after a good bit of experimentation I've got something I'm fairly happy with and which other might like to play with.
Here's Stonemason's 'Streets of the Med' (plus a few other bits and pieces) in the morning.
PoserPro 11 - Units: Metres
Adobe CC 2017
cspear posted Wed, 18 April 2012 at 12:26 PM
Adobe CC 2017
Adobe CC 2017
cspear posted Wed, 18 April 2012 at 12:29 PM
Note that the only change for these renders was the position of the "Sun".
Anyway, here's the mat files (mt5) and instructions. (Knock the ".txt" off the end).
Enjoy! Feedback, suggestions etc. welcome.
EDIT: the zip file's too big. Bear with me while I sort something out....
Adobe CC 2017
Snarlygribbly posted Wed, 18 April 2012 at 12:33 PM
Looks good!
Can't see the attachment though?
Free stuff @ https://poser.cobrablade.net/
cspear posted Wed, 18 April 2012 at 12:44 PM
Adobe CC 2017
Adobe CC 2017
hborre posted Wed, 18 April 2012 at 1:04 PM
Always on the lookout for skydome textures. I'll give these a try. Thanks.
Miss Nancy posted Wed, 18 April 2012 at 2:17 PM
they look very good. use raytraced sun to get shadow edge blur. no blur on shadow edges next to the object casting the shadow, then the blur increases as the shadow edge gets farther away from the object. bill did a cloud procedural for the sphere, but it has hundreds of nodes IIRC.
p.s. I just checked outside and the noon shadow edge had a blur width of ~1 cm at 1 m, ~3 cm at 3 m, but it may not be linear. hence it would only be obvious in relatively close shots.
bagginsbill posted Wed, 18 April 2012 at 3:18 PM
Question: I included an effects shader that will turn ordinary day clouds into serious storm, sunset, etc. Did you:
or
bagginsbill posted Wed, 18 April 2012 at 3:19 PM
Original sky
cspear posted Wed, 18 April 2012 at 4:00 PM
BB, yes I've used the effects shader many times - what I'm trying to achieve is a method of generating my own cloud shapes / distributions / positions, rather than rely on stuff from flickr etc.
The other thing I'm going to have a stab at is to whip out my DSLR and make some equirectangular HDR maps, when time permits.
Adobe CC 2017
RobynsVeil posted Wed, 18 April 2012 at 6:23 PM
Any pointers you might be willing to share on how you make those equirectangular HDR maps would be gratefully read, CSpear... I just purchased a Canon T3i and would love to give it something to do.
estherau posted Wed, 18 April 2012 at 7:17 PM
I use vue for making my skies. I just load an atmosphere then render with panorama and spherical set and HDRI and out it comes.
estherau posted Wed, 18 April 2012 at 7:18 PM
then i map it onto the BB envirsphere of course.
RobynsVeil posted Wed, 18 April 2012 at 7:55 PM
Hm, on Vue 10 Studio, I don't have a Panorama setting. I have Panavision and Ultra-Panavision: are these the same thing? And where is the spherical set? A lot of my setting appear to be disabled. :blink:
estherau posted Wed, 18 April 2012 at 8:18 PM
panoramic view under dpi setting - it's there
and check that little box underneith for spherical render.
RobynsVeil posted Wed, 18 April 2012 at 8:32 PM
Oh, got it - I was looking in the drop-down. Thanks, Esther.
estherau posted Wed, 18 April 2012 at 8:57 PM
also in vue if you use the panorama setting (without sherical renders) you can get some really nice vue renders by adjusting the angle.
cspear posted Thu, 19 April 2012 at 6:17 AM
Quote - Any pointers you might be willing to share on how you make those equirectangular HDR maps would be gratefully read, CSpear... I just purchased a Canon T3i and would love to give it something to do.
RobynsVeil, I'll be using something called 'Stitcher' which is now part of the Autodesk stable, because that's what I have. It's a pig of a thing to use though - clunky, slow, idiosyncratic interface - it's main advantage being that it produces great results. And it's expensive.
There's an OpenSource thing called Hugin which might be worth a look. It'll do equirectangular HDR images according to the documentation but I haven't tried that.
Adobe CC 2017
Anthanasius posted Thu, 19 April 2012 at 11:33 AM
Quote - BB, yes I've used the effects shader many times - what I'm trying to achieve is a method of generating my own cloud shapes / distributions / positions, rather than rely on stuff from flickr etc.
I agree, equirectangular are nice, but we never found what we want.
Great job :D
RobynsVeil posted Thu, 19 April 2012 at 4:59 PM
Have installed Hugin in Ubuntu (painless). Reading the docs...
"Although Hugin is essentially a panorama stitcher, like other GUI front-ends it has a range of advanced features:
Among the Hugin workflow options, it is possible to correct exposure, Vignetting and White balance between photos; generate HDR, exposure fused or focus stacked output from bracketed photos; or use 16bit and HDR input data natively.
Photos can be digital or scanned, and taken with any kind of camera. A full range of lenses are supported, from simple cameraphones to obscure fisheye lenses. Hugin supports various output projections including a range of spherical, cartographic, and camera projections.
Hugin supports panoramas taken with multiple rows of photos, with or without bracketing. Bracketed photos can be handheld, taken using a DSLR bracketing function, or as consecutive panoramas shot at different EV exposure levels. Hugin can produce successful panoramas shot with cameras that always shoot using auto-exposure and auto-whitebalance."
...let you know how I go. It does support Python scripting, which is pretty cool. Thanks for the tip, CSpear.
