Subject: Eporting Image With no Background
DOSHL opened this issue on Apr 18, 2012 · 6 posts
DOSHL posted Wed, 18 April 2012 at 1:10 PM
Hello,
I want to export a rendered figure from Poser Pro 1012 as a .png file and open it in another application - Flash - with no background.
When I try to export the image as a .png file, it opens in Flash with the upper top of the image with no background - just the figure.  But, the bottom half of the image has the figure and the background from Poser.
How can I export the image so that the entire background is transparent?
wimvdb posted Wed, 18 April 2012 at 1:14 PM
Turn off the ground (or set it invisible)
Turn off Ground Shadows as well if you don't need it
hborre posted Wed, 18 April 2012 at 1:20 PM Online Now!
Ditto.
DOSHL posted Wed, 18 April 2012 at 1:21 PM
How do you turn off the ground or set it invisible and how do you turn off ground shadows?
wimvdb posted Wed, 18 April 2012 at 1:26 PM
From the menu: Display!Guides!Ground Plance - uncheck it
Or - Select then Ground in the Pose Window and Uncheck Visible in its properties
Disable Ground Shadows: From menu: Display!Ground Shadows - uncheck it
bagginsbill posted Wed, 18 April 2012 at 3:07 PM
Also Ctrl-G
