timoteo1 opened this issue on Apr 20, 2012 · 3 posts
timoteo1 posted Fri, 20 April 2012 at 2:30 AM
Hi:
I went to do some illumination baking in Vue 10 and noticed that is only using a fraction of my processing power for the Illum. bake. It is ignoring all threaded cores completely, and only using a small percentage of the four real cores.
Any idea why, and any known way to force it to use all cores? I can't see how this would be a GPU assigned task, so I'm at a loss. If it would just use all of a computer's capabilities (as at render time), it surely would be done in a fraction of the time.
Any insight into this matter would be greatly appreciated. **Thanks! **
-Tim
MaryHines posted Fri, 20 April 2012 at 9:59 AM
when my Vue does that, I usually have to close Vue, close all other windows, open task manager/services, make sure there's nothing else running that might be causing a strain on Vue...
then i reopen Vue,, go to task manager/processes...rightclick on Vue, make sure its priority is set to 'normal'
timoteo1 posted Fri, 20 April 2012 at 10:20 AM
This will happen when Vue is first loaded even. It's as if they didn't write the code to take advantage of all the cores when Illum. baking or something. I just tried it with a freshly loaded scne and CPU usage is only at the 12% I previously mentioned.
Now if Vue would let you work on something else inside it while it was baking that would fine, but this seems like such a waste.
-Tim
