WandW opened this issue on Apr 20, 2012 · 17 posts
WandW posted Fri, 20 April 2012 at 9:08 AM
I have a V4WM character that uses the Leg Length Morphform to shorten the legs. This uses Single Axis Scaling to adjust the length, so it causes distortion when the shin is bent. Using the PP2012 dependency editor I created an ERC that adjusts the Z Translation of the shin over the bend range to keep it pretty, and it works well. Is there an easy way to get this ERC into conforming clothing, or will she be doomed to wear baggy pants and skirts?
Thanx in advance
PS, I do have match scales on conforming checked for the item (V4 bodysuit) I'm testing with...
PPS; I did try futzing with the joint centers, but it caused other distortions.
