DOSHL opened this issue on Apr 26, 2012 · 2 posts
DOSHL posted Thu, 26 April 2012 at 10:52 AM
I wrote yesterday regarding a Flash export problem from Poser Pro 2012. The problem was importing the swfs into either Flash CS5 Professional or Player. Upon import Flash would crash.
I did more testing and found that the same Poser files exported as swfs from Poser Pro 2010 imported just fine into Flash with no crashes.
Has anyone else worked with Flash export in Poser Pro 2012? The problem seems to be with Poser Pro 2012.
Any suggestions?
ToxicWolf posted Fri, 27 April 2012 at 2:53 PM
File a report with SM. The more they get the more they will think about stuff that needs fixing. I had a real problem with memory usage by 2012 that does not exist in 2010 when I run the exact same pz3 file. They took it pretty well, but we will see if a fix ever comes out.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
