Subject: any wolverine claws around?
Tucan-Tiki opened this issue on May 05, 2012 · 11 posts
Tucan-Tiki posted Sat, 05 May 2012 at 8:57 AM
I made these but not happy how they turned out.
dlfurman posted Sat, 05 May 2012 at 12:29 PM
Perhaps, scaling (down) would be in order. They are the right shape, just too big.
Length wise a bit too long, and the height should smaller as well. (These look like they have popped out from between his fingers and out of his palms. The claws actually pop from the back of the hand, though some artists renderings vary.)
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD space
Tucan-Tiki posted Sat, 05 May 2012 at 1:47 PM
think I got the shape right just a pain in the butt to get them xyz;d
Tucan-Tiki posted Sat, 05 May 2012 at 1:49 PM
second set seems to have come out right these are beveled just like in the film was really hard finding an approach that would get them to look beveled.
hborre posted Sat, 05 May 2012 at 1:54 PM Online Now!
This is what you are looking for:
http://www.renderosity.com/mod/bcs/index.php?ViewProduct=72609
Tucan-Tiki posted Sat, 05 May 2012 at 1:56 PM
they are still not exact but this is as close as i can get and i like this set better then the first try at it, looks alot closer to the film design then  the first mesh i made.
Tucan-Tiki posted Sat, 05 May 2012 at 2:02 PM
lol I think my blades are more movie accurate but the prop would help I could scale mine to match it I suppose.
ToxicWolf posted Sat, 05 May 2012 at 2:12 PM
Your claws look great Tucan-Tiki. Just need a little scale work and you should have it. What did you use to make them?
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
Tucan-Tiki posted Sat, 05 May 2012 at 2:20 PM
i got true space 3 and 4 running in windows 2000, windows 200 wont install it no matter what you try so I purchased a sea gate 500 gig external that came with a windows xp enviroment on it i installed it on the seagate and then moved it to my hard drive and it worked fine.
Tucan-Tiki posted Sat, 05 May 2012 at 2:31 PM
i also use zbrush but the learning curve on that thing is monsterious it's as bad a rhino, truespace is easy because you can do everything in one window and hardly have to switch views which is why i like it. but it is very limited if you want to create organic models like people or animals but it will just about anything else that does not have nurb like contours like car for instance not happening, it would be very tough to model in truespace unless you did it in sections and parts but it would be one hell of a pain, but houses, furniture,clothing props stuff like that even poser hair it's great for.
ToxicWolf posted Sat, 05 May 2012 at 3:55 PM
Thanks Tucan-Tiki. I'll have to give Truespace a try. I downloaded it today. I have problems with Lightwave and it looks like Silo is no longer supported.
Poser Pro 2012 SR3
24G RAM
