Forum: Bryce
Subject: Moon orbiting a second moon, orbiting a planet
satasha opened this issue on May 09, 2012 · 7 posts
satasha posted Wed, 09 May 2012 at 10:19 PM
Hi. I am trying to animate a moon orbiting a second moon, orbiting a planet. Here is the hard part: I would like their orbits to not be at 90 degree angles! Also I would like the moons and planets to be spinning. Is this all doable? If so how?
Mysteral posted Thu, 10 May 2012 at 3:07 AM
You could try making the planets spin by setting up an animation in the Materials Lab.  For each sphere, open the Mat Lab, set the materials you wish to use on the sphere, probably, an imported texture may be best here.  (see skiwillgee's excellent mini tut, making image based materials for Bryce ) then set the timeline at the bottom of the Mat Lab window so that the texture image rotates through 360 degrees.
I've not tried it with more than one sphere, but I wonder if you could even get the planets to spin at different rates. Anyway, this should free up your animation time line to concentrate on the planetary orbits.
Good luck. Hope to see a link on here to your work if it's successful.
As a writer, I control the lives of millions. Whole worlds can be destroyed by typing the correct sequence of letters on my keyboard.
Robert A. Read
Rayraz posted Thu, 10 May 2012 at 3:18 PM
I think this can be done with some parenting and manipulation of the origin coordinates of the moons.
Lets start with a naming convention so my explaination makes sense:
The planet's name is: "Planet 1"
T the moon orbiting the planet is: "Moon 1"
The moon orbiting Moon 1 is: "Moon 2"
Setting up the animation:
I would take the Moon 2 and put its origin at the center of its orbit around Moon 1, which would probably also be the center of Moon 1. You can then animate the rotation to make Moon 2 orbit its parent (Moon 1).
Also, make Moon 1 the "parent" of Moon 2 ao that Moon 2 will follow Moon 1.
Now take the Moon 1 and put its origin at the center of its orbit around Planet 1, which would probably also be the center of Planet 1. You can then animate the rotation of Moon 1 to orbit its parent (Planet 1).
The result should be as follows:
Simulated axial rotation:
If you want the moons and planets to look like they rotate around their axis (instead of being tidally locked) you can animate their textures to reflect this.
Actual axial rotation:
Another option, if you need to rotate the moons around their axis without animating their texture. You could do the same as above, only you replace Moon 1 and Moon 2 with an intermediary object (lets call it a "null object").
This Null Object be anything, a sphere, a cube, doesnt matter as long as its an object and its made to be invisible during render time (hence the name "null object"). Then you animate the null object to orbit as if it were the moon (see my original example).
When the Null Object has its orbit, you turn the Null Object into the Moons' parent, so that the moons will follow the intermediary Null Object in its orbit.
Finally, now that the moons are following the Null Object, their origin point can be left unchanged at their center. Now, when you animate the rotation of the moons, they'll rotate around their axis, while following their null parents in orbit around their parent moon/planet.
The catch:
There is only one catch.. in older versions of bryce, using animation and parenting of objects used to be buggy, and sometimes it would break down entirely, messing up the animation quite horribly. I dont know if this has been fixed in bryce 6 or 7 because i never tried anything like this since bryce 5, but just in case it is still buggy, i recommend making a back-up of your un-animated scene before trying the above.
(_/)
kiwi_gg posted Sat, 12 May 2012 at 2:18 PM
This has been answered over in the Bryce forum at Daz3d with an excellent video tutorial by Oroborus.
Cheers
GG
WHO said Kiwi's can't Fly ?????
satasha posted Sun, 13 May 2012 at 3:03 AM
Thanks Rayraz.
FranOnTheEdge posted Sat, 04 August 2012 at 2:59 PM
Quote - This has been answered over in the Bryce forum at Daz3d with an excellent video tutorial by Oroborus.
Cheers
GG
I can't find it - do you have a link?
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
satasha posted Sat, 04 August 2012 at 10:45 PM
Looks like they moved or deleted the thread.
Here is the video link on youtube:
http://www.youtube.com/watch?feature=player_embedded&v=vQZiS1hykw4
