Forum: Carrara
Subject: Models of water puddles
DFWasserboehr opened this issue on May 20, 2012 · 9 posts
DFWasserboehr posted Sun, 20 May 2012 at 12:52 PM
I am trying to create water puddles ona flat floor. Does anyone have any tips on how to create these models?  Thanks
lazycatstudio posted Sun, 20 May 2012 at 2:30 PM
Create a polyline outline in the vertex modeler and use Construction->Organic
DFWasserboehr posted Sun, 20 May 2012 at 4:48 PM
Thanks, where do I find construction>organic?
GKDantas posted Sun, 20 May 2012 at 6:14 PM
I use the metaball modeler, them stretch them...
Follow me at euQfiz Digital
lazycatstudio posted Sun, 20 May 2012 at 9:37 PM
Construct->Organic actually
headwax. posted Mon, 21 May 2012 at 2:25 AM
hya
when i Construct->Organic  on my polyline zilch happens
any clues appreciated :)
edit : ah you have to fill the polys first : - '0
Kixum posted Mon, 21 May 2012 at 8:57 AM
I'm still a little confused about what you're after but here's a thread which might be what you're talking about.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2825282
-Kix
lazycatstudio posted Mon, 21 May 2012 at 9:03 AM
The manual and the in-program error message are wrong about the Organic tool for recent versions of Carrara. It now doesn't work on polylines anymore but on single polygons.
SirCamillo posted Wed, 23 May 2012 at 5:09 PM
Water color is a result of transparancy, reflection and refraction.  Create a flat plane slightly above your floor. UV map.  Paint a map for your puddle and create an alpha mask. In the puddle area you can add transparancy, reflection and refraction along with bump to get the look of water.
Camillo
Animation can explain whatever the mind of man can conceive.
Walt Disney
