3dcheapskate opened this issue on May 22, 2012 · 5 posts
3dcheapskate posted Tue, 22 May 2012 at 9:47 AM
Deep in the Asian jungle they face each other across the clearing, each armed with a pair of dha, the long-handled, slightly curved, single edged swords of the region. A sudden lunge with a powerful right hand blow - the opponent ducks and blocks deflecting the vicious swing overhead. The right-hand counterattack was anticipated and is solidly blocked too. But who are the two combatants? Any pair of these 28 supported figures...
You need to have DAZ Studio or Poser, and the figures, facial expressions, hair, clothing and jungle (or other) scenery already in your library.
This set provides you with the swords and two poses, plus a couple of handy (pun intended!) scripts.
What's Included:
Sword Prop (Poser 6 PP2 / DAZ Studio DSA): a sword prop with 8 morphs. The geometry (500 faces) is in an external OBJ file. (The DAZ script loads the Poser prop with DS mats automatically applied)
Sword Texture (1024x1024 JPGs): a basic rattan & steel sword texture (texture map, bump map, and UV template (PNG) included)
Sword Mats (DAZ Studio DSA material preset / Poser 6 MC6): a basic rattan & steel sword texture (1024x1024 bump/texture JPGs)
Hand Poses (Poser 6 HD2): A single sword grip hand pose for each of the 28 supported figures. (N.B. some of them aren't very good at all!)
Full Body 'Paired' Poses (Poser 6 PZ2): Two poses for each of the 28 supported figures. The Hip parameters of each pose are set so that when used together the poses will be facing each other with the sword blades clashing.
Full Body 'Solo' Poses (Poser 6 PZ2): Identical to the paired poses, except that the Hip is only adjusted vertically (to put the feet on the ground) and not rotated.
Partial Poses (Poser 6 PZ2): Upper/lower body only versions of each of the two poses for each figure, to combine with other poses from your library.
*Sword Smart+ Script: Effectively a smartprop sword that automatically applies the correct sword grip hand pose.
*PropGoto+ Script: Similar to the Smart+ script, but using a sword prop that's already loaded.
(All DAZ Script and PoserPython files are in plain ASCII text format for you to examine, rework, laugh at, etc)
*The PoserPython scripts probably won't work with later versions than Poser 6 due to their use of the Poser 6 PoserPython User Interface. For this reason I've included versions of both PoserPython scripts with all User Interface elements removed - these may or may not get around the problem (if there is one). These scripts are clearly marked as Test versions.
*Tested with Poser 6, DAZ Studio 3 and DAZ Studio 4 on a Windows 7 PC.
More info on my website
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
3dcheapskate posted Tue, 22 May 2012 at 10:04 AM
3dcheapskate posted Tue, 22 May 2012 at 10:17 AM
Scripts are in plain text format - feedback on the Poser versions to this thread in the PoserPython scripting forum please.
3dcheapskate posted Tue, 22 May 2012 at 10:21 AM
kenmo posted Wed, 23 May 2012 at 9:06 AM
Looks awesome... I'll be downloading once I get home from work....
