MatCreator opened this issue on May 30, 2012 · 9 posts
MatCreator posted Wed, 30 May 2012 at 9:01 AM
I totally forgot =/
What are the command keys to export an object from the Bryce Preview Window?!?
We had to have the "edit" prompt open for it to work correct?!?
Brain has been butter for a while =/
There are 3 kinds of people in the
world. Those that can count, and those that can't..
kiwi_gg posted Wed, 30 May 2012 at 12:53 PM
"control d" if My old memory is correct . Later versions of bryce its in the "file" dropdown menu.
CheeRs
GG
WHO said Kiwi's can't Fly ?????
MatCreator posted Wed, 30 May 2012 at 4:46 PM
I tried that, it's not working tho =/
I do see the export option, didnt know the other method was removed.
Thanks a ton =D
skiwillgee posted Wed, 30 May 2012 at 8:36 PM
Ctrl+d will duplicate a selected object.
MatCreator posted Wed, 30 May 2012 at 9:01 PM
Youre correct skiwillgee, but when the edit prompt is open, it "used" to begin an export function.
Seems it's been replaced/removed and is in the edit menu now.
kiwi_gg posted Thu, 31 May 2012 at 12:47 AM
AFAIK both are correct. I think it was 6.3 where the "control d" from the edit option where you did smooth/unsmooth on exit you were given a list of file formats you could export to, this function was moved to the file>export position.
Cheers
GG
kiwi_gg posted Thu, 31 May 2012 at 2:40 PM
With your object highlighted you must have the "E" visible in the dropdown menu, click on this to bring up the edit mesh window where you will have the option to smooth/ unsmooth your object. Without doing any smoothing operation if you hold down "control + d" and "exit the edit mesh window" at the same time you are then presesented with a save window from where the object can be saved in a number of other file formats.
"control+d" still works in my Bryce 6.3 but no longer available in 7pro where you now do File>export. Screen-shot is from B5.5.
Cheers
GG
MatCreator posted Fri, 01 June 2012 at 4:40 AM
So long as the function exists =)
Shows how out the loop I am...
bobbystahr posted Fri, 01 June 2012 at 9:12 AM
what kiwi_gg said....
Once
in a while I look around,
I see
a sound
and
try to write it down
Sometimes
they come out very soft
Tinkling light sound
The Sun comes up again
