clay opened this issue on Jun 17, 2012 · 56 posts
clay posted Sun, 17 June 2012 at 2:48 PM
Do atleast one thing a day that scares the hell outta ya!!
TheBryster posted Sun, 17 June 2012 at 3:04 PM Online Now! Forum Moderator
Way cool effect, Clay!!!
clay posted Sun, 17 June 2012 at 3:18 PM
I'll post the .mat file if anyone is needing such a thing..but it will cost one trillion dollars!!! USD LOL!
dyret posted Sun, 17 June 2012 at 3:38 PM
Thats CHEAP!
clay posted Sun, 17 June 2012 at 3:38 PM
Side note: this is one of those "things" that came up during testing to see if we could do it with the basic bryce settings, so the answer is.. yes it can be done :-) with a bryce mat or a reflection map, most overlooked feature methinks in the mat lab.
FranOnTheEdge posted Sun, 17 June 2012 at 7:26 PM
That's pretty nice Clay, reminds me of the irridescense mats in the Bryce backroom (which I think are no longer there unfortunately), but different.
I'm sure I can find a reference for a dollar somewhere online - could probably make you a bunch of Bryce dollars for it?
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
clay posted Sun, 17 June 2012 at 7:30 PM
clay posted Sun, 17 June 2012 at 7:45 PM
FranOnTheEdge posted Sun, 17 June 2012 at 7:57 PM
OOOh nice! I hope you'll tell us how to do this - since you're going to be nice and let us play with it. I don't think I've ever used a 'reflection map' before.
Measure
your mind's height
clay posted Sun, 17 June 2012 at 8:05 PM
Just add a second pebble in the mat lab on reflection and add an image or mat preset for reflection.
FranOnTheEdge posted Sun, 17 June 2012 at 8:35 PM
I guess it depends on what you use in there - thinking about it I've only ever used the same image in there that I've used in other places in the same texture, and I don't think they worked too well, cos I'd click in the same channel that say diffuse was using, and usually that made the resultant material very dark.
I've just tested it using one of my sky photos, and even that can darken the texture too much. There must be a trick to using it.
Measure
your mind's height
clay posted Sun, 17 June 2012 at 8:52 PM
Just have to tweak.
clay posted Sun, 17 June 2012 at 8:55 PM
Attached Link: http://claygraphics.phase2.net/Iridescence.br7.zip
Here you can download and fiddle around with it.Do atleast one thing a day that scares the hell outta ya!!
Mysteral posted Mon, 18 June 2012 at 2:31 AM
Looks excellent from the images Clay.
However, When I download the zip file from your link, it unzips to Iridescence.br7 for PC and Mac. When I load the file into Bryce 7 Pro, I'm asked to "Please Locate 15.jpg" If I try to Cancel, Bryce crashes. Do you have any idea why? And where should one find 15.jpg?
[quote]Here you can download and fiddle around with it.
As a writer, I control the lives of millions. Whole worlds can be destroyed by typing the correct sequence of letters on my keyboard.
Robert A. Read
FranOnTheEdge posted Mon, 18 June 2012 at 4:56 AM
Yup, me too. Bryce crashes, and I can't do anything about it because I too don't have your 15.jpg.
It also crashes if you try to replace the missing 15.jpg with an image of your own, I just tried it.
Measure
your mind's height
dan whiteside posted Mon, 18 June 2012 at 7:10 AM
Very cool effect but on my MacPro (Intel) it loads fine, no find file message, but it crashes as soon as the wireframe complets drawing. This coming from a Mac PPC?
clay posted Mon, 18 June 2012 at 12:54 PM
oops yeah forgot I added the image in the reflection node, and yeah Dan from a PPC, I'll re upload in a bit without the image.
FranOnTheEdge posted Mon, 18 June 2012 at 12:59 PM
Awwww! You could just add the image to the zip.... (hopeful expression)
Measure
your mind's height
clay posted Mon, 18 June 2012 at 1:08 PM
Attached Link: http://claygraphics.phase2.net/Iridescence.zip
ok here ya goDo atleast one thing a day that scares the hell outta ya!!
clay posted Mon, 18 June 2012 at 2:01 PM
ok it should have the cloud image in there now, download from above message.
FranOnTheEdge posted Mon, 18 June 2012 at 2:26 PM
Um... nope, not working.
There seems to be an error with the jpeg - nothing will see it, not windows picture viewer, not PowerArchiver, not Bryce, not Corel PaintShopPro PhotoX2, nor Adobe PhotoShop - nothing.
And Bryce still crashes...
Measure
your mind's height
clay posted Mon, 18 June 2012 at 2:32 PM
Hmm well I'll re upload without the image in the reflection node, then you can just add your own image for reflection. ok try it again, when its open, just click on the pebbles for reflection, diffusion and ambient and load whatever you want to reflect.Do atleast one thing a day that scares the hell outta ya!!
FranOnTheEdge posted Mon, 18 June 2012 at 3:43 PM
It's still asking for 15.jpg, Clay... and still crashing
Measure
your mind's height
clay posted Mon, 18 June 2012 at 3:56 PM
Ha! WOW!!!! Ok here's what I'll do, I'll just upload the .mat file, then you just add that to whatever sphere or half dome object that is in the shape of a lens. Apparently even after shutting off the map in the mat lab then resaving the file Bryce is still trying to re-call cached file paths. Gimme a minute and I'll repost just the .mat file.
clay posted Mon, 18 June 2012 at 4:01 PM
Attached Link: http://claygraphics.phase2.net/Iridescence.mat.zip
Ok, try this, just load this .mat into like your glass presets or whatever:-)Do atleast one thing a day that scares the hell outta ya!!
FranOnTheEdge posted Mon, 18 June 2012 at 4:14 PM
In the meantime I've been trying to create something of the sort myself... (not too well, but there's something there)
So I'm very eager to see what your Iridescence.mat holds...
Measure
your mind's height
clay posted Mon, 18 June 2012 at 4:15 PM
Just a rainbow type thing in the DTE, nothing to fancy. When you do anistropic type effects like you would use on a CD reflection etc it can get a little more in depth.
FranOnTheEdge posted Mon, 18 June 2012 at 4:43 PM
Can you show a screen shot of the material settings you used - with your 15.jpg?
I'll try that on my sky image then, but at the moment I'm just guessing - I think the middle lens is more like a CD.... Lol!
The left one has your mat - the right 2 have mine.
Oh, and your sky settings might make a difference too... so if you could manage a screen shot of them too... ?
Measure
your mind's height
clay posted Mon, 18 June 2012 at 4:54 PM
Attached Link: httphttp://claygraphics.phase2.net/iridecent.zip
Ok try this one LOL!Do atleast one thing a day that scares the hell outta ya!!
FranOnTheEdge posted Mon, 18 June 2012 at 5:54 PM
But I still want to see your mat settings for the image you add to the various channels like reflection, diffusion, ambient.
Then maybe I can tweek my mats and yours too, & see what comes up.
But I'm about ready to call it a day for today, it's time for bed here in the UK. So I'll have another go at it tomorrow.
P.S. you've got 2 https on the link.
By the way that's a nice telescope/spyglass model
Measure
your mind's height
clay posted Mon, 18 June 2012 at 6:16 PM
just add an image in the mat lab on the 2nd reflection pebble, that's all.
FranOnTheEdge posted Tue, 19 June 2012 at 7:56 PM
Yeah,
I have been doing.
But I'm not getting what you are getting, I'm trying for something like the second image:
And it's just not getting there, this looks like a different model to the telescope, and I'm wondering what you are using as a backing just behind the lens, I've been trying various different materials on a 2d disc positioned just behind the half sphere I'm using as a lens.
So is this just the cut off front end of the telescope? I can see you've got a pretty low refraction value on the lens.
I've worked at this for a while now, and I can't get any better effect than the second from the right, and I can't seem to get the iridescence that you get.
I think there are just too many factors involved in this that I don't know.
Measure
your mind's height
clay posted Wed, 20 June 2012 at 10:55 PM
I just used basic black on a 2d disc didn't I?
clay posted Wed, 20 June 2012 at 10:59 PM
clay posted Wed, 20 June 2012 at 11:00 PM
Its what I used in the original where it said it would load or whatever.
dan whiteside posted Thu, 21 June 2012 at 7:15 AM
Thanks Clay - all is good!
FranOnTheEdge posted Thu, 21 June 2012 at 6:09 PM
There's something weird about the lens in your model.
Weird in as much as I can get better iridescence on that than I can on a shape that looks exactly similar but made in another prog (Wings), but I can't get the same effect on it.
Here are a couple of attempts:
And another:
Comparison of the top 2 in particular shows that the lens on the left has more variation in colour than the right one (Right is Wings, left is Clay's), but both use same image.
Here however I am using a different image on the WingsLens on the right:
When I use the same image, the colour is predominately blue as the left one is now, but the colour differences are more subtle.
Measure
your mind's height
clay posted Thu, 21 June 2012 at 10:07 PM
Hmm I used Maya to make the half dome, maybe it has something to do with it being a subdivided object being exported from maya, interesting heh.
FranOnTheEdge posted Fri, 22 June 2012 at 4:23 AM
I think it's partly something to do with the fact that it's just a shell, not a complete half dome, and partly to do with the smoothing that's made up the facets of the shape.
I have other smoothing methods in Wings, which I'm going to try - or I might also try modeling it in C4D too, if Wings' smoothing doesn't manage it.
Was it a hypernurbs object? And yeah, it's fascinating the difference the modelling method on a simple half dome can make.
Measure
your mind's height
TheBryster posted Fri, 22 June 2012 at 6:00 AM Online Now! Forum Moderator
More HERESY!!!!
FranOnTheEdge posted Fri, 22 June 2012 at 5:25 PM
Yes Bryster, but we are at least doing things IN BRYCE. Now there, there, have a little sit down... I'm sure we can find you a nice comfy chair somewhere...
...someone keeps leaving a lot of them about!
Clay, was the lens object UVmapped?
I was wondering if the mapping I've been using (Camera Projection in Wings) might not be the best option?
I can't stand Unfolding for this sort of shape, it twists too much, but UVMapper Classic cuts the map up, (as does Cinema) into 2 long strips (weird!)
But I also don't think cutting the two half poles (as if it was a complete sphere) would help much... so I wondered what you'd used, Clay?
Measure
your mind's height
clay posted Fri, 22 June 2012 at 8:44 PM
no not uv mapped, in Maya I just created a simple polygon sphere and only had it revolve 180 degrees instead of a full 360 that would make the full sphere, that's all, its just a 1/2 a sphere LOL!
FranOnTheEdge posted Fri, 22 June 2012 at 9:39 PM
Revolve? That sounds like it was made from a spline.
Measure
your mind's height
clay posted Fri, 22 June 2012 at 11:13 PM
No, you cancreate an object in maya and if you just click it to create it, it will create the whole object, then you can select its attribute dials and tell it "hey I only wanted that partilly created, and use a slider to create however much you want of the object.
FranOnTheEdge posted Sat, 23 June 2012 at 2:14 PM
Oh really? It's a long time since I tried learning Maya from a 30 day demo... and failed. And I don't remember such partial creation being possible back when I was at uni either. But then I didn't learn much of it.
Well whatever you used I seem to have fallen into a well of 'how did he do that' and 'I must figure it out', so I think I'll stop now, it's been an interesting exercise and I've discovered that you can use adjusted images for your sky reflection, souped up ones!
Measure
your mind's height
skiwillgee posted Sat, 23 June 2012 at 8:20 PM
I've been away for a week or so and return to see this awesome thread. Thanks, Clay!
I've faxed you a 20 pound box of money for sharing this.
clay posted Sun, 24 June 2012 at 2:09 PM
BTW Fran, I just went and re-did my half dome, its a nurb object where I can manipulate the dementions, 180 etc etc, then I convert it to a polygon object within maya, but the more spans you give it the smoother it becomes, so a lil bad on my part:-)
FranOnTheEdge posted Mon, 25 June 2012 at 2:10 PM
Oh so it is a nurbs model - I wondered about that earlier.
Just a thought, have you tried out irridescence on anything else apart from a lens?
Measure
your mind's height
clay posted Mon, 25 June 2012 at 3:55 PM
Yup, works perfect on everything I have tried, of course I'm a lil weird though heheh.
goofygrape posted Thu, 28 June 2012 at 1:20 AM
Clay this looks fun,but I get 404 on the links .So I'll lurk.
clay posted Thu, 28 June 2012 at 10:08 PM
Attached Link: http://claygraphics.phase2.net/iridecent.zip
Here Goofygrape:Do atleast one thing a day that scares the hell outta ya!!
goofygrape posted Tue, 03 July 2012 at 1:35 AM
Thanks Clay
The Grape is very happy now
John
mikedaddysmooth posted Mon, 09 July 2012 at 11:30 PM
I would love to try it, but the link doesn't exist.
You should never doubt what no one is even sure about.
clay posted Tue, 10 July 2012 at 12:39 AM
Link works fine.Do atleast one thing a day that scares the hell outta ya!!
mikedaddysmooth posted Tue, 10 July 2012 at 1:36 AM
clay posted Tue, 10 July 2012 at 1:39 AM
Most welcome:-)
