meatSim opened this issue on Jul 02, 2012 · 28 posts
meatSim posted Mon, 02 July 2012 at 1:39 AM
I'm working on a SciFI helmet for Antonia and I'm wondering if anyone has any ideas for sci fi gadgets or doodads that might be incorporated into a helmet. I have a light on one side and I'd like to balance out the other side with a slightly boxy gizmo of some sort. I'll post a picture as soon as my render finishes
meatSim posted Mon, 02 July 2012 at 1:45 AM
thoughts?
monkeycloud posted Mon, 02 July 2012 at 4:14 AM
Looks great
I'd agree a gentler curve to the head shape would be good. Again, I think having a morph or two for this sort of area is good. You could allow the end-user to morph the helmet shape between the narrower, slightly more pointed shape above and something going maybe more bulbous?
Perhaps some sort of speaker grille for the mouth section? (e.g. to transmit the wearer's voice from within the helmet).
I kind of like the asymmetry going on with the head lamp. Maybe the opposite temple of the helmet (from the one with the headlamp) could just be reserved for decals? (e.g. wearer id number, military insignia or whatever)
The other idea I had was to have a smaller, directional light on the other temple... maybe a small lamp on a poseable stalk?
If a more boxy, control panel type idea, then maybe a small LED display showing something resembling a brain scan (or whatever image the end-user wants to add for that mat zone, if you made the LED display have its own mat zone perhaps) would look cool?
Perhaps if you made these various details hideable, it would increase the options?
SamTherapy's latest Dalek Poser figures feature geometry switching controlled by parameter dials, to change various features about. It's a very cool way of providing multiple choices to the end-user...
cheers
lesbentley posted Mon, 02 July 2012 at 8:49 AM
How about a video camera, like in the film Aliens? Or a laser (complete with red laser beam)?
P.S.
I think one of us needs to calibrate our monitor, I can hardly see the helmet in the image you posted.
moriador posted Mon, 02 July 2012 at 9:03 AM
Quote - How about a video camera, like in the film Aliens? Or a laser (complete with red laser beam)?
P.S.
I can see it very clearly, but it is a dark image. My monitor is set with minimum brightness but it's wide gamut -- it passes all the visual tests, except gamma, which is always a tradeoff. Then again, I can also see the picture very clearly, though more brightly, on my horrible cheap monitor. Sounds like yours is about to die.
meatSim posted Mon, 02 July 2012 at 11:05 AM
Thanks for some great input! I'm not entirely sure how to do some of it (geometry switching, and calibrating my monitor to be specific) The mouth section is a separate material zone so quite a bit could be done with textures and dislacement. There is a raised flat area in the center of the forehead for a 'crest' or insignia of some kind, but a spot for decals, unit info or something might be good on that side as well. I'm fond of the assymetry as well, so maybe just by rounding out the top and bringing that temple area angled more steeply might be enough. My other thought was to add a sort of communications gizmo on that side. I think something kind of boxy to contrast with smooth curves of the rest of the piece.
meatSim posted Mon, 02 July 2012 at 11:09 AM
meatSim posted Mon, 02 July 2012 at 11:17 AM
That is pretty cool... I like the little camera, but I didn't want things to look too similar with the light on the other side. however If i grouped that in with a communications thingamabob it could all fit in a rounded rectangular sort of housing with a small antenna poking up. I'd also be able to add more light emitters, which I love!
Quote - i guess you can do something like this ..
I made them addons to the epsilon outfit at DAZ
BAR-CODE posted Mon, 02 July 2012 at 11:27 AM
Attached Link: IMAGE
lets try it one more time :..
sorry ..i have removed my posting ..in my browser nothing showed up ..
Maybe becuase i had to switch to my other "bar-code" account to get the image..
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A PM to 26FAHRENHEIT "same person"
Chris
MikeMoss posted Mon, 02 July 2012 at 12:02 PM
Hi
These images all appear too dark, on my computer, they are barely visible.
If everyone is seeing it this way, and you aren't, then you need to calibrate your monitor.
But from what I can see it looks pretty cool!
Mike
This looks more or less correct on my monitor... I don't know why it got narrow, I pasted it in the same size I copied it.
If you shoot a mime, do you need a silencer?
BAR-CODE posted Mon, 02 July 2012 at 12:07 PM
Attached Link: IMAGE maybe maybe not i dunno anymore ...
okay 3 times strike out ..http://www.renderosity.com/mod/gallery/media/folder_181/display_1804295.jpg
Chris
Chris
monkeycloud posted Mon, 02 July 2012 at 12:09 PM
Your renders do look pretty dark to me too meatsim... is there a light source other than the helmet light in your scene there?
Cheers
MikeMoss posted Mon, 02 July 2012 at 12:15 PM
That's better!!!
For a space look I'd use a single source white light, I removed a lot of yellow to correct this.
Nice looking helmet, I love the glowing red LEDs on the knobs.
Yuroven posted Mon, 02 July 2012 at 12:24 PM
antenna? an idea
lesbentley posted Mon, 02 July 2012 at 12:39 PM
These links should help with Monitor calibration.
meatSim posted Mon, 02 July 2012 at 1:03 PM
the image itself is actually pretty dark, its just using the light in the helmet (not sure if it was a light emitter or a parented poser light in that image) and a starfield image on BB environment sphere for light.
I just grabbed images that I had in the render history, and most of them were from messing around with the light emitter or point light embedded in the light housing of the helmet.
I'll do up a 'normal' light level render later on today.
lesbentley posted Mon, 02 July 2012 at 1:42 PM
Quote - I'm not entirely sure how to do some of it (geometry switching, and calibrating my monitor to be specific)
There are two parts to geometry switching, code to identify the geometries, and a channel to swap between the different geometries. Note that what follows is from a figure. I have not tested it in a prop.
Here is an example that will swap between 4 different geometries (including the default), you would place this code immediately above the 'channels' line in the actor you want to swap the geometry for:
alternateGeom geom_001
name geom_001
objFile 1001 :Runtime:Geometries:YourName:ProductFolder:object_001.obj
alternateGeom geom_002
name geom_002
objFile 1002 :Runtime:Geometries:YourName:ProductFolder:object_002.obj
alternateGeom geom_003
name geom_003
objFile 1003 :Runtime:Geometries:YourName:ProductFolder:object_003.obj
Then add this channel as the last channel in the channel stack:
geomChan AltGeom
uniqueInterp
name AltGeom
initValue 0
hidden 0
forceLimits 1
min 0
max 3
trackingScale 0.045
keys
static 0
k 0 0
interpStyleLocked 1
The name "AltGeom" is just an example, you can use any name. "The 'max' limit should be equal to the number of alternate geometries. When the dial is set at zero the default geometry will be used. To have a blank geometry (no geometry) you can either leave the geometry out of the base obj for that actor, or you can create an empty file named "blank.obj" and use that as one of the geometries to be swapped.
For adding parts to a helmet, it may be better to create an extra actor as a child of the helmet, and switch geometry for that part, rather than switching between different versions of the whole helmet.
meatSim posted Mon, 02 July 2012 at 2:33 PM
well.... it seems my monitor found its way onto game mode at some point.. so a bunch of the images I thought were pretty good are significantly less so now... though I'm not sure I performed the monitor calibration right at all...
My monitor has an sRGB mode that doesnt allow any changes to contrast, brightness, or colour temp... should I trust that they have it set correctly and just use that?
meatSim posted Mon, 02 July 2012 at 2:43 PM
Whatever I add will be separate geometry. It was real pain to build the light geometry and then weld it into the mesh of the helmet. I think I'll make a little ridge surrounding whatever I want to add in, duplicate those faces and scale that by 0.995% (to create a fine crevice between the helmet and the module) and build whatever I build from that base. That way I can put whatever Modules I want into the 'slot' without too much trouble
I'll worry about how to code the whole thing later.. I havent mucked around inside a poser file yet so I'll have to suck up some courage first
Quote - > Quote - I'm not entirely sure how to do some of it (geometry switching, and calibrating my monitor to be specific)
name geom_001
}alternateGeom geom_002
name geom_002
}alternateGeom geom_003
name geom_003
}Then add this channel as the last channel in the channel stack:
geomChan AltGeom
uniqueInterp
name AltGeom
initValue 0
hidden 0
forceLimits 1
min 0
max 3
trackingScale 0.045
keys
static 0
k 0 0
interpStyleLocked 1
}The name "AltGeom" is just an example, you can use any name. "The 'max' limit should be equal to the number of alternate geometries. When the dial is set at zero the default geometry will be used. To have a blank geometry (no geometry) you can either leave the geometry out of the base obj for that actor, or you can create an empty file named "blank.obj" and use that as one of the geometries to be swapped.
meatSim posted Mon, 02 July 2012 at 3:11 PM
lesbentley posted Mon, 02 July 2012 at 6:59 PM
Looks good!
TheOwl posted Mon, 02 July 2012 at 9:20 PM
Something like from splinter cell?
A rotating visor? night vision, Infrared scope, sonar scope...
Passion is anger and love combined. So if it looks
angry, give it some love!
meatSim posted Tue, 03 July 2012 at 12:04 AM
Thats pretty cool. That might be something to do separately so it could be worn by itself or with just the mask portion of the helmet
meatSim posted Tue, 03 July 2012 at 12:48 AM
monkeycloud posted Tue, 03 July 2012 at 2:01 AM
Doodad housing looks great. Shaping up nicely
meatSim posted Tue, 03 July 2012 at 3:26 AM
And last one before bed.. added some clasps. All UV mapping now done. Just need to model a back piece and work on some textures and I can put this one to bed!!
monkeycloud posted Tue, 03 July 2012 at 3:30 AM
Cool. Like it! Those clasps really set it off well... particularly with the head shape the way it is...
cheers
meatSim posted Tue, 03 July 2012 at 10:56 AM
Thanks... I couldn't widen out the top as much as I wanted and keep a nice smooth curve so I had to improvise. I might push the clasps out just slightly and make a little seal or gasket(?) looking thing where they meet the helmet
