Subject: Looking for this vintage style bather
Zev0 opened this issue on Jul 06, 2012 · 19 posts
Zev0 posted Fri, 06 July 2012 at 4:28 AM
I need this type of bather or clothing. Must be the identical style. Any available?
My Renderosity Store
Zev0 posted Fri, 06 July 2012 at 4:29 AM
more ref...
Gremalkyn posted Fri, 06 July 2012 at 4:57 AM
That is a top over a bottom, so maybe a pull over shirt.  If not, can you use this?
http://www.renderosity.com/mod/bcs/retrogirl/88233
Zev0 posted Fri, 06 July 2012 at 5:07 AM
ah ur right. I thought it was one piece... cool. Now to find that shirt
Gremalkyn posted Fri, 06 July 2012 at 5:12 AM
"Tankini" is, I think, what you want - according to Ujena (my go-to for swimwear ideas).
http://www.ujena.com/xbikini-details.php?cid=185&pid=A328&st=A328
Notice the cut of the top?  Hard to see with the matching color and short on the hem line, but I think that is the cut in your first pic.  Now, to find a Poser version . . . :p
This swimdress is a bit long.
http://www.ujena.com/xbikini-details.php?vv=237&mm=A313
Anyway, more terms for searching. :)
Zev0 posted Fri, 06 July 2012 at 5:42 AM
Its cool. I already just took a shirt into Zbrush and modified it. Thanks for your help.
pitklad posted Fri, 06 July 2012 at 5:47 AM
Judy has one on her default garderobe
My FreeStuff
Zev0 posted Fri, 06 July 2012 at 6:12 AM
The outfit doesnt curve on the thigh. Its horizontal. So a tanktop extended lower is what I used. It must have a straight edge.
lesbentley posted Fri, 06 July 2012 at 6:53 AM
Perhaps a catsuit with a transparency map?
Zev0 posted Fri, 06 July 2012 at 7:22 AM
Problem with a catsuit is that it shrink wraps to the body around the hip area. It must straight across both thighs. A modified tank top did the trick. Just extended the lengh.
KristiS posted Fri, 06 July 2012 at 10:28 AM
Not sure if this will work for you or not, but thought I would share it with you just in case:
http://www.renderosity.com/mod/bcs/rg-swimsuit-t1-for-v4a4g4elite/71114
Kristi
Community Relations Specialist
This is your life - your platform - your stage - your story
gloomy007 posted Fri, 06 July 2012 at 12:00 PM
Propschick has Beachy Keen , maybe you can make breast part invisable and replace it with a halter top from SEA by fabiana ;)
DAZ Studio Coordinator.
You can contact me in english.
Jij kan mij berichtje sturen in Nederlands,
Mozesz sie ze mna skontaktowac po Polsku
Lully posted Fri, 06 July 2012 at 12:14 PM
I get a pretty good result from this outfit, just hide the fur bit by making it invisible in the mat room and alter the rest of the mat zones to suit
http://www.evilinnocence.com/xmas-08-for-v4.html
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape,  Classic UVMapper, and several headache tablets.
Zev0 posted Fri, 06 July 2012 at 2:59 PM
Kristis and Lully those are perfect. Since Lully's is the free option I'll go with that:) Gloomy007, the outfit MUST have straps so unfortunately your choice is not an option. The bottom section of that set is however is perfect. Thank you all:)
KristiS posted Fri, 06 July 2012 at 4:07 PM
You are very welcome...so glad you found something you can use😄
Have a fantasic weekend!!
Kristi
Acadia posted Fri, 06 July 2012 at 8:38 PM
Try these:
XMas freebie by Mada at FaereWylde
50's Texture for above swimsuit
Water Fun by Nirvy
Acadia posted Fri, 06 July 2012 at 8:54 PM
Here is another:
Retro Girl Textures by Renapd
3D Ages Swimsuit
Acadia posted Fri, 06 July 2012 at 9:01 PM
Here are some textures for Roogna's swimsuit listed above
http://www.sharecg.com/v/34540/browse/11/Poser/TD-RGSwimWear-T1-Textures
Zev0 posted Sat, 07 July 2012 at 6:22 AM
:) downlaoded them all. Thanks Acadia:) Not going to use retro girl though. The bottom shape is incorrect. Lully's example was the closest to what I was looking for.
