Subject: Change D3 to M4
Michaelab opened this issue on Jul 08, 2012 · 13 posts
Michaelab posted Sun, 08 July 2012 at 10:39 AM
I'm sure this has been asked before:
Is there an easy way/plugin to change my meticulously crafted face of my D3 character to an M4 character? I have Poser 8.
CyberDream posted Sun, 08 July 2012 at 10:48 AM
There is an extensive thread covering moving morphs from one character to another.
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2677445&page=1
I've used it to transfer V3 morphs to V4
Michaelab posted Sun, 08 July 2012 at 12:36 PM
Thank you, CyberDream, but what did you exactly use when you say you used 'it'? Could you point me to what 'it' is?
CyberDream posted Sun, 08 July 2012 at 1:09 PM
Quote - Thank you, CyberDream, but what did you exactly use when you say you used 'it'? Could you point me to what 'it' is?
http://www.the.cage.page.phantom3d.net/TDMT_Match/TDMT.html
Michaelab posted Sun, 08 July 2012 at 1:36 PM
that page doesn't exist anymore.
WandW posted Sun, 08 July 2012 at 2:21 PM
Quote - that page doesn't exist anymore.
It is there.  It is on the same server as Poser Place, which has a DNS issue from some ISPs, so see that thread for the solution...
CyberDream posted Sun, 08 July 2012 at 2:25 PM
The page is fine, I copied the link from it when I visited it to answer your question
mihoshi1de posted Sun, 08 July 2012 at 2:27 PM
I can't reach it either... :-/
Medzinatar posted Sun, 08 July 2012 at 2:58 PM
Quote - I can't reach it either... :-/
I don't suppose you bothered to check the thread referenced by WandW above
mihoshi1de posted Sun, 08 July 2012 at 3:11 PM
Quote - > Quote - I can't reach it either... :-/
I did, but I lost oversight what you all need for the script to work, as it seems at the end of the other thread there's another script introduced as well as a link to another thread... but I'll check again in a quieter minute. But I felt like adding that the site is unavailable not only for the OP.
Michaelab posted Sun, 08 July 2012 at 3:24 PM
yes, agreeing with mihoshi1de, it gets rather confusing what is needed. there are a few links and a long couple of threads. it's not easy to sort through and if the end result is that you need the link to work, then it's not for me.
Tucan-Tiki posted Tue, 10 July 2012 at 2:38 PM
is that even possible are they the same mesh?
Medzinatar posted Tue, 10 July 2012 at 2:59 PM
Quote - is that even possible are they the same mesh?
That was the whole point of referencing Cage's thread on transferring morphs between different meshes
