false1 opened this issue on Jul 10, 2012 · 9 posts
false1 posted Tue, 10 July 2012 at 12:58 PM
I'd gotten away from using Bryce for many years. The last version I remember using was Bryce 3D way back in the day (may have used 4 though). I also downloaded 5.5 free when it was offered but I don't know if it ever was used.
I remember an earlier version that came with editable scene files on the disk. Probably 10 or 20 scenes created by Bryce masters that you could open in Bryce and poke around with. I thought it was an excellent way to get a feel for the scale of landscapes and planetscapes from distant galaxies.
Now that I'm getting back into Bryce I'm having questions about sizing items. Should a distant planet be smaller and closer to the foreground or larger and farther away? How does that effect the textures, atmousphere or rendering times.
Any idea if those kind of files are still available?
________________________________
kiwi_gg posted Tue, 10 July 2012 at 1:49 PM
I think you are talking about the "companion files". Did'nt daz start them somewhere around the release of B5.5??? Not sure as I never bothered with them.
Cheers
GG
WHO said Kiwi's can't Fly ?????
false1 posted Thu, 12 July 2012 at 8:50 AM
No problems. I found them on Daz's website under "Bryce 5 content pack". Not sure if it has all the scenes I remember but a pretty good start. I wonder if the terrains and gels and such are any different than what comes with B7 already?
MatCreator posted Fri, 13 July 2012 at 2:54 PM
I'm admittedly VERY curious as to what files you speak of =/
But to answer your question, I believe the common way is to take a sphere and shoot it wayyyy into the back, then enlarge as needed...
You can preview how much distance effect is given, and see how it interacts w/ the atmosphere... There arent any "set" rules, just go for the "end visual"... Bryce has always been about trickery, doesnt have to be planet size or millions of miles away in order to give the appearance of being that far and that big... All illusions, if that makes any sense.
Good timing, I just added a TON of Bryce presets to the freestuff section, hope it can help you in your quest =)
There are 3 kinds of people in the
world. Those that can count, and those that can't..
false1 posted Fri, 13 July 2012 at 3:17 PM
Comes down to trial and error and render, render, render. I need to experiment with more haze and clouds so the planets don't look as close.
The files I found aren't the same as I remember. There were many, many more. I'm not sure if those old files would even open in the latest Bryce anyhow. The ones I found really look dated these days. I think they used ol school materials.
MatCreator posted Fri, 13 July 2012 at 4:43 PM
I don't even remember the files you speak of... Old age?!?
orbital posted Sun, 15 July 2012 at 6:47 AM
http://www.imaginefx.com/02287754333273104115/tutorial.pdf
There is some handy tips on here regards creating planets and getting the right sky.
false1 posted Mon, 16 July 2012 at 1:48 PM
Quote - http://www.imaginefx.com/02287754333273104115/tutorial.pdf
Very Helpful,
thanks
FranOnTheEdge posted Sat, 04 August 2012 at 9:50 AM
I got another load of free scene files with the Bryce 4 Bible, and with the download for Bryce 5.5 too. With every version I'm pretty sure. That's why I always save the presets before I do anything else. Every version, then I add them and save again, so that now I have all the presets and scene files from every version I've had, (except 4 I think) as well as all the ones I've made myself.
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
