arrow1 opened this issue on Jul 12, 2012 · 14 posts
arrow1 posted Thu, 12 July 2012 at 6:12 AM
Custom built computer 128 gigs RAM,4 Terabyte hard drive, NVIDIA RTX 4060 TI 16 GIG Gig,12 TH Generation Intel i9, Dual LG Screens, 0/S Windows 11, networked to a Special 12th Generation intel I9, RTX 3060 12 Gig, Windows 11,64 gigs RAM, Dual Phillips Screens, 2 Terabyte SSD Hard Drive plus 1 Terabyte Hard Drive,3rd Computer intel i7,128 gigs ram, Graphics Card NVIDIA RTX 3060 Gig,1 Terabyte Hard Drive, OS Windows 11 64 Bit Dual Samsung Syncmaster 226bw Screens.Plus INFINITY Laptop 64 Bit,64 gigs RAM.Intel i9 chip.Windows 11 Pro and Ultimate. 4 x 2 Terrabyte Hard Drives and 2 x 2 Terrabyte external USB Hard drives. All Posers from 4 to Poser 2010 and 2012, 2014. Poser 11 and 12, 13, Hexagon 2.5 64 Bit, Carrara 8.5 Pro 64 bit, Adobe Photoshop CS4 Creative Production Suite. Adobe Photoshop CC 2024, Vue 10 and 10.5 Infinite Vue 11 14.5 Infinite plus Vue 15 and 16 Infinite, Vue 2023 and 2024, Plant Catologue, DAZ Studio 4.23, iClone 7 with 3DXchange and Character Creator 3, Nikon D3 Camera with several lenses. Nikon Z 6 ii and Z5. 180-600mm lens, 24-70 mm lens with adapter.Just added 2x 2 Terrabyte portable hard drives.
Amigo968 posted Thu, 12 July 2012 at 8:55 AM
Did you save the poserimport to an vob (vue object)? If I import Poserfigures to Vue, I open a new scene, import the figure and saved it under an vue object (mouse rightclick save object). In my existing scene I load this vob's and there are no problems with my NVidia FX card. Try to change the preferences from Open GL 2.1 (shader 4) to Open GL (fixed hardware pipeline).
ShawnDriscoll posted Thu, 12 July 2012 at 8:59 AM
After, does Vue let you attempt to start it with safe mode video? Then Vue can do its "Let's detect your video adapter" routine. Are you using the second video choice in your Vue display settings? The top one is very iffy.
If that still doesn't work, download that last full non-beta driver for your adapter before you completely gut out your current video driver (uninstall it and also delete any folders left behind). Then reboot and let windows grab the boring CGA driver :)
Then run the install you downloaded. Reboot. Let Vue do its detecting. Load your Vue scene again.
If still the same error, it then comes down to what version of Poser you have and what Poser SDK you have selected.
QXI posted Thu, 12 July 2012 at 2:10 PM
What driver version are you using? The 270. driver was completely worthless with Vue and produced this error repeatedly along with numorus crashes and aggrevating hours of re-work. If you just upgraded your driver try going back one driver to see if your system produces the same error. The 300 series drivers so far seem very compatable with vue 10 complete at this point for me. Hope this helps!
arrow1 posted Thu, 12 July 2012 at 6:43 PM
Many thanks for your replies.To answer Amigo968.Yes! I imported my Poser Pro 2012 figures and saved them as VOB's. I will change the Open 2.1 shader 4 to Open GL (fixed hardware pipeline) and see if that does the trick. I will keep you all informed.Cheers
ShawnDriscoll posted Thu, 12 July 2012 at 6:53 PM
I never knew you could save a Poser figure as VOB. I know exporting is not allowed. So what happens when someone else tries to open the VOB on their system? Does their Vue allow it? It seems it would be blocked from happening.
arrow1 posted Thu, 12 July 2012 at 7:50 PM
The problem I am having is when I make an adjustment to either the pose or props in Poser.Vue then reconizes these adjustments and asks if I want to make the changes in Vue.I say yes! The adjustments are made then Vue 10.5 Infinite crashes with the above error. I then go to Poser and it also crashes with the same error. I have also as suggested changed the preference to Open GL pipeline hardware..It also crashes my system.I may have to look at my Nvidea drivers. I am presently running PC Tune Up.It has so far found over 1400 problems. Vue usually does not have any problems importing both still and animated Poser figures and saving them as VOB's. I am also trying to cancel the previous Beta Update to Vue.I have selected this option in Vue but it shuts down and nothing happens! Cheers
arrow1 posted Thu, 12 July 2012 at 7:59 PM
Just for the record my NVidea card is a GE Force GTS 240 with Driver version 301.42. Cheers
Amigo968 posted Thu, 12 July 2012 at 8:45 PM
Which version of poser do you use for the import?
arrow1 posted Thu, 12 July 2012 at 8:47 PM
Poser Pro 2012 SR2 with the latest SDK. Cheers
Amigo968 posted Thu, 12 July 2012 at 9:28 PM
I shall try this tomorrow at my pc, now I have to go to bed sleeping.
arrow1 posted Thu, 12 July 2012 at 11:30 PM
I have reinstalled Vue 10.5 Infinite.Poser figures seem to be importing ok.However I keep getting "Unsupported jpg's for the textures maps for the hair"Any ideas? Cheers
arrow1 posted Fri, 13 July 2012 at 4:06 AM
Well I have managed to recreate my scene.Vue can be amazing when it want's to be.I do not know the full extent of my problem but reinstalling Vue and unistalling the update drivers seems to have cured the crashing problem. Also not installing the Vue beta update seems to have also assisted.Why I say Vue can be amazing is I have just rendered a scene with six Poser and DAZ figures some of them weight mapped and a ecosystem 4000 pixels wide at 240 dpi.There is still some problems with not all textures being imported however I can work around that in Photoshop.Many thanks to all you great people who assisted me in my problem.Hopefully happy rendering.Cheers
Amigo968 posted Fri, 13 July 2012 at 5:59 AM
If some textures are not correct imported to Vue, you can adjust (play a little bit with the sliders at the tabs) the transparency tab in the materialeditor.
