timarender opened this issue on Jul 13, 2012 · 4 posts
timarender posted Fri, 13 July 2012 at 6:13 AM
Please excuse me if I am using the wrong terminology.
I want to apply a graphic which is not a Material in the Library. Manually, I would open the Material room, create an 'Image Map', choose the selected graphic; and then apply the image map to Diffuse Color.
Using script, I could use "LoadMaterialCollection" to apply a material from the Library. But that does not work with a graphic outside the Library, eg: d:tempa.jpg
Can anyone point me in the right direction, please.
Alternatively; is there a scripting way to take a bunch of graphic file and convert them into materials?
I appreciate all this may involve itinerating through materials etc. But, I am really getting lost in the Poser Python manual.
Thanks for any assistance.
millighost posted Fri, 13 July 2012 at 8:42 AM
It should roughly look like this:
import poser
scene = poser.Scene ()
actor = scene.CurrentActor ()
material = actor.Materials ()[0]
shader = material.ShaderTree ()
image_map = shader.CreateNode (poser.kNodeTypeCodeIMAGEMAP)
path_input = image_map.InputByInternalName ("Image_Source")
path_input.SetString ("d:my_image.png")
surface = shader.NodeByInternalName ("PoserSurface")
shader.AttachTreeNodes (surface, "Diffuse_Color", image_map)
timarender posted Fri, 13 July 2012 at 9:28 AM
That was very helpful. Thank you very much for taking the time to assist me.
bagginsbill posted Fri, 13 July 2012 at 11:28 AM
Even easier with matmatic. It's a one-liner.
for name in os.listdir("some folder here"): if name.endswith(".jpg"): outputs += ["=Material[%s]" % name, Surface(ImageMap(name), .8)]
Of course I'm just showing off and that's not really a finished script as there would be some manipulation of the path name. But the part of making the material for each image file is correct:
Surface(ImageMap(imageFileName), .8)
