Subject: How do I change a hair item from hair folder so that it is able to fit either si
rowlando opened this issue on Jul 14, 2012 · 13 posts
rowlando posted Sat, 14 July 2012 at 1:54 AM
I want to change the hair called Magdalin hair so that the hair can fit either side of v4 head,.
This is because the right side of the hair is set to be behind the v4 right ear, and I want it to fit on the left v4 ear.
its basically a from right to left fit
cheers Rowlando
Seek what you can never loose
CyberDream posted Sat, 14 July 2012 at 2:13 AM
first, is it CR2 or HR2?
Next, what is the correct spelling of the name and maybe who is the vendor.
rowlando posted Sat, 14 July 2012 at 2:38 AM
HR2
madelyn hair by neftis
CyberDream posted Sat, 14 July 2012 at 3:15 AM
export the hair out as OBJ, use your favored modeling program to mirror the file.
bring it back in, parent to head and apply materials.  You will lose all the morphs in this process
cspear posted Sat, 14 July 2012 at 3:41 AM
Dimension3D has a mirror utility that works on just about anything.
PoserPro 11 - Units: Metres
Adobe CC 2017
CyberDream posted Sat, 14 July 2012 at 4:02 AM
D3D makes some very elegant software and if it does preserve morphs, it is well worth the price.
I mirrored the madelyn hair and put both on some zero posed V4's squished together
rowlando posted Sat, 14 July 2012 at 4:39 AM
Hi cyberdream
can you give me the name of the software that you used it looks exactly what I want.
And thanks to all the others for the suggestions
cheers Rowlando
rowlando posted Sat, 14 July 2012 at 4:42 AM
is D3d a member here at rendo I can't see the name in marketplace
rowlando posted Sat, 14 July 2012 at 4:55 AM
Found it I think
by dimension3d
content mirror for poser
3doutlaw posted Sat, 14 July 2012 at 8:09 AM
Wouldn't the Symmetry -> swap left and right command work?
LaurieA posted Sat, 14 July 2012 at 8:56 AM
Quote - Wouldn't the Symmetry -> swap left and right command work?
Nah ;) That only transfers joint settings from one side to the other. Laurie
3doutlaw posted Sat, 14 July 2012 at 10:11 AM
Ah...a new nugget of wisdom every day!  :)
lesbentley posted Sat, 14 July 2012 at 4:43 PM
Here is a way to mirror hair, the instructions that follow are for conforming hair, but the process is similar for prop hair.
1). Load the hair, don't conform it. Zero the translations and rotations of the hair figure. In P9/PP2012, you can do that via the Zero Figure button in the Figure menu.
2). With the hair's Neck actor selected, create a magnet. Select the Mag Base, make sure its xTran is zero.
3). Select the Mag Zone, make sure its xTran is zero, set its scale to be 5000.0.
4). Select the Mag, set its xScale to be 0.001.
5). Select the hair's Neck actor, from the Object menu, select 'Spawn Morph Target', Name the morph "Mirror", click 'OK'. Delete the magnet. Set the Mirror morph to a value of 2.0.
6). Open the Grouping Tool. Select 'Reverse normals'. Close the Grouping Tool.
7). Memorize the hair, then Save the hair figure to a the figures library (you will not be able to save it to the hair library).
As far as the morphs go, some may still work correctly, particularly those that only affect up-down motion of the hair, or front back motion. Morphs that only affect side-side motion should work but will require a negative dial value. Morphs that affect side-side and also affect up-down or front-back, will not work correctly.
