Subject: Save conforming paints with adjustments
skogzort opened this issue on Jul 14, 2012 · 2 posts
skogzort posted Sat, 14 July 2012 at 9:37 AM
Hello,
I have a set of conforming paints and top. I was able to adjust the Top from Pose tab and save it as a new figure, but when I try to do the same with the paints, they get “reset”. When I try to add them to a figure, I have to do the adjustments all over again.
Is there a way around this? - I'm pretty new to Poser, but don't mind doing something difficult to make this work
Thanks a lot for any help
Lully posted Sat, 14 July 2012 at 10:10 AM
If you are adjusting using the morph dials, you could try and memorise the item, After tweeking the figure, select body, go to the function on the edit dropdown menu and choose 'figure' then resave the cr file as a new name.  When reloading it should keep the morphs.
Tools:- Win10, Dell XPS8900, ZBrush, Marvelous Designer 11, Hex 2, PSP8. PSP 2019 Ultimate, DAZ Studio, Affinity Photo, Affinity Designer, Filterforge 11, flowscape,  Classic UVMapper, and several headache tablets.
